I think it could be great and very usefull to create a custom Tab where we can group Switch. Just to organize. For the air cooling or warm it is very bad. We have mode (on/off/warm/cold/...) and fan (1,2,3,4,5, night,...) in switch tab, in utility tab we have Temperature and in Temperature Tab the temperature of the room...very complex.
we should be able to assign temperature in different tabs and assign switch to one or more custom tabs too. Like this we could manage air cooling, alarm on different tabs.
what do you think about this ?
Group in UI
Re: Group in UI
Have you tried the roomplans already? You can put in there anything you like, even one device in two roomplans
- bueno79
- Domoticz version: 4.9700
Re: Group in UI
Of course we use room plan but this is not enough. Moreover room plan is not perfect on phone.
I've tried other domotic solution and Domoticz have the most flexible UI but hard to customize the code. We should rebuild UI in Angular. As of today the backend seems very solid but UI is not as it should be for a modern tool.
Aurora UI is a good start but not enought flexible.
If look after the Camera only... we have no way to manage Camera like other product. So we use motioneyes...
