Dashticz 2.5.3
Dave47
Domoticz version: 2023.1
Dashticz 2.5.3
Post by Dave47 »
I i use parameter in Dashticz_v2 behind Apache server
	buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
or
	buttons.webcam = {width:12, isimage:true, refresh:2000, image: 'http://Myip/snapshot.cgi?user=user&pwd=pwd', url: 'http://Myip/snapshot.cgi?user=user&pwd=pwd'}
dashticz is very slow and sometimes stuck for 20 seconds.
I also have a dashticzv2 running not behind apche server and than it is no problem.
How can i solve the problem behind the Apache server?
Lokonli
Re: Dashticz 2.5.3
Post by Lokonli »
Dave47 wrote: Monday 11 February 2019 14:17 I i use parameter in Dashticz_v2 behind Apache server
or
When using Dashticz with Apache:
Which PHP version is reported by Dashticz? (press the settings button in the top bar, and then look at the info tab)
Do you also have a slow Dashticz if you remove buttons.webcam?
What is in CONFIG.js your current setting for config['default_cors_url']?
What is the result if you add the following setting to CONFIG.js:
config['default_cors_url']='https://cors-anywhere.herokuapp.com/'
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
Php 7.0.33-0+deb9u1
yes, but at the moment i have a solution with forcerefresh:true.... is that ok?
I have no config['default_news_url'] at the moment. It is also very slow.
and i use
columns[1] = {}
columns[1]['blocks'] = ['news']
columns[1]['width'] = 5;
I can see the news!
Braadkippie
Re: Dashticz 2.5.3
Post by Braadkippie »
I use Synology, how can I update Dashticz for an new version?
HansieNL
Re: Dashticz 2.5.3
Post by HansieNL »
Download latest Beta version from https://github.com/Dashticz/dashticz_v2/tree/beta and overwrite old version.
DON'T FORGET TO BACKUP YOUR CUSTOM FOLDER(S)
Blah blah blah
Braadkippie
Re: Dashticz 2.5.3
Thanks a lot!
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
Sometimes https://cors-anywhere.herokuapp.com/ gives an error?
What is wrong?
Lokonli
Re: Dashticz 2.5.3
Post by Lokonli »
Dave47 wrote: Sunday 17 February 2019 21:14 Sometimes https://cors-anywhere.herokuapp.com/ gives an error?
What is wrong?
yes, especially when you call cors-anywhere frequently. (herokuapp uses some kind of rate limiter)
In fact that's the reason an internal CORS proxy was added to Dashticz.
However, it only works if PHP is installed.
You enable the CORS proxy in Dashticz by removing the 'default_cors_url' setting in CONFIG.js, and by removing all other references to cors-anywhere.
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
After remove all references to cors i can also use default_news_url without using cors in the url?
I think PHP is ok?
Lokonli
Re: Dashticz 2.5.3
Post by Lokonli »
Dave47 wrote: Monday 18 February 2019 7:19 After remove all references to cors i can also use default_news_url without using cors in the url?
yes
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
How does the url look like for News?
Can jou give me a example?
Http://?
Lokonli
Re: Dashticz 2.5.3
Post by Lokonli »
Dave47 wrote: Monday 18 February 2019 12:53 How does the url look like for News?
Http://?
You can use:
config['default_news_url'] = 'http://www.nu.nl/rss/Algemeen';
and then add 'news' to a column definition.
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
I can see the news for a while and then I have to refresh the page
Is there a problem in Dashticz at the moment?
Lokonli
Re: Dashticz 2.5.3
Post by Lokonli »
Dave47 wrote: Tuesday 19 February 2019 12:56 I can see the news for a while and then I have to refresh the page
Yes, will be fixed in the next beta.
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
I see there is a update. Can i update from the settings screen in Dashticz?
Lokonli
Re: Dashticz 2.5.3
Post by Lokonli »
No, not really.
Dave47
Re: Dashticz 2.5.3
Post by Dave47 »
What is the best to install the latest beta 2.5..4?
silver323
Re: Dashticz 2.5.3
Post by silver323 »
Well, copied from the wiki page:
cd /home/pi/dashticz_v2
git pull
However, my advise is to store a backup of your existing dashticz-folder, clone the latest release, and copy your previous config files to the fresh Dashticz installation:
cd /home/pi
mv dashticz_v2 dashticz_v2_bak
git clone https://github.com/robgeerts/dashticz_v2 --branch beta
cd dashticz_v2/custom
cp ../../dashticz_v2_bak/custom/CONFIG.js .
cp ../../dashticz_v2_bak/custom/custom.css .
