Temperature setpoint problem
Posted: Sunday 10 February 2019 17:38
by rodaman
I have especially bought Domoticz Pro app to have full controll of my Domoticz setup. I found out it is not possible to set temperature higher than 30'C in virtual thermostat. I have to controll my boiler and fireplace. It is very disapointed. Why it is so difficult to change it? Many users ask for it.
Re: Temperature setpoint problem
Posted: Monday 11 February 2019 8:58
by Gerwin
if you use the app, go to settings then to standard settings and here you can set the maximum and minimum temperature you can set as setpoint
Posted: Monday 11 February 2019 9:47
by rodaman
Thank you very much. It works finally... :D
Posted: Monday 09 September 2019 22:38
by Jonkheer
I've installed Evohome with 4 remote controlled thermostats. The system is connected to Domoticz with the Evohome web interface. It's possible to change the setpoints of each thermostats in the API. But I can't change the set point with the Domoticz app.
Posted: Monday 09 September 2019 23:14
by waaren
Jonkheer wrote: Monday 09 September 2019 22:38 I've installed Evohome with 4 remote controlled thermostats. The system is connected to Domoticz with the Evohome web interface. It's possible to change the setpoints of each thermostats in the API. But I can't change the set point with the Domoticz app.
on my (Android) mobile I have no problem changing the setPoint. What are your settings / versions ?
Posted: Thursday 12 September 2019 21:48
by Jonkheer
Version 0.2.135 built 6204 which is recent according to playstore. Selecting the device in the app gives me only the option to see the logging (day, month, year), the favorite option and info button which opens a new window with IDX number an the last seen status.
Posted: Thursday 12 September 2019 22:48
by waaren
Jonkheer wrote: Thursday 12 September 2019 21:48 Version 0.2.135 built 6204 which is recent according to playstore. Selecting the device in the app gives me only the option to see the logging (day, month, year), the favorite option and info button which opens a new window with IDX number an the last seen status.
I use the same version. (selected temperature devices)
selected "Zet"
Posted: Monday 16 September 2019 9:52
by Jonkheer
waaren wrote: Thursday 12 September 2019 22:48
Exactly what I had suspect on my device, but it's only performing as as thermometer. I'm missing the "Zet" button.
Posted: Tuesday 08 October 2019 20:41
by Jonkheer
Suggestions anyone?
It’s only an issue for the Android devices. Some in house IOS systems (with Pilot) are also able to set the temperature.
