Temperature setpoint problem
rodaman
Post by rodaman »
I have especially bought Domoticz Pro app to have full controll of my Domoticz setup. I found out it is not possible to set temperature higher than 30'C in virtual thermostat. I have to controll my boiler and fireplace. It is very disapointed. Why it is so difficult to change it? Many users ask for it.
Gerwin
Re: Temperature setpoint problem
Post by Gerwin »
if you use the app, go to settings then to standard settings and here you can set the maximum and minimum temperature you can set as setpoint
rodaman
Post by rodaman »
Thank you very much. It works finally... :D
Jonkheer
Domoticz version: 2023.2
Post by Jonkheer »
I've installed Evohome with 4 remote controlled thermostats. The system is connected to Domoticz with the Evohome web interface. It's possible to change the setpoints of each thermostats in the API. But I can't change the set point with the Domoticz app.
Jonkheer wrote: Monday 09 September 2019 22:38 I've installed Evohome with 4 remote controlled thermostats. The system is connected to Domoticz with the Evohome web interface. It's possible to change the setpoints of each thermostats in the API. But I can't change the set point with the Domoticz app.
on my (Android) mobile I have no problem changing the setPoint. What are your settings / versions ?
Jonkheer
Post by Jonkheer »
Version 0.2.135 built 6204 which is recent according to playstore. Selecting the device in the app gives me only the option to see the logging (day, month, year), the favorite option and info button which opens a new window with IDX number an the last seen status.
Jonkheer wrote: Thursday 12 September 2019 21:48 Version 0.2.135 built 6204 which is recent according to playstore. Selecting the device in the app gives me only the option to see the logging (day, month, year), the favorite option and info button which opens a new window with IDX number an the last seen status.
I use the same version. (selected temperature devices)
selected "Zet"
Jonkheer
Post by Jonkheer »
waaren wrote: Thursday 12 September 2019 22:48
Exactly what I had suspect on my device, but it's only performing as as thermometer. I'm missing the "Zet" button.
Jonkheer
Post by Jonkheer »
Suggestions anyone?
It’s only an issue for the Android devices. Some in house IOS systems (with Pilot) are also able to set the temperature.
