Is there a simple way to extract a value from the report ? :
I'd like to take the value in red (total daily cost) and receive it everyday as a notification.
I'm not sure that it's possible
Thank you
This works for my P1 meter.pimseb wrote: Sunday 10 February 2019 10:03 Hello,
-- getDailyUsageReport
local httpResponses = "getDailyUsageReport"
timer = { "at 06:07" },
httpResponses = { httpResponses }
logging = {
level = domoticz.LOG_DEBUG,
marker = httpResponse
execute = function(dz, item)
-- ****************************** Your settings below this line ***************************************************
energyDevice = dz.devices(35) -- Replace with ID of energyDevice you want to track
textDevice = dz.devices(1492) -- Create as virtual text device and change 1492 to the ID of the new device
-- ****************************** No changes required below this line *********************************************
local Time = require('Time')
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function triggerJSON(energyDevice)
local URLString = dz.settings['Domoticz url'] .. "/json.htm?range=year&sensor=counter&type=graph&idx=" .. energyDevice.id
dz.openURL({ url = URLString,
method = "GET",
callback = httpResponses })
local function showResult(str)
textDevice.updateText(str)
logWrite(str,dz.LOG_FORCE)
dz.notify("Yesterday's usage: ", str)
local function getResult(rt)
local yesterday = os.date("%Y-%m-%d",os.time()-1*24*60*60)
local dayBeforeYesterday = os.date("%Y-%m-%d",os.time()-2*24*60*60)
local yesterdayTotal, dayBeforeYesterdayTotal
for key in ipairs(rt) do
if rt[key].d == yesterday then
yesterdayTotal = rt[key].c1 + rt[key].c3 - rt[key].c2 - rt[key].c4
elseif rt[key].d == dayBeforeYesterday then
dayBeforeYesterdayTotal = rt[key].c1 + rt[key].c3 - rt[key].c2 - rt[key].c4
return yesterdayTotal - dayBeforeYesterdayTotal
if not item.isHTTPResponse then
elseif item.ok then -- statusCode == 2xx
showResult("Usage : ".. dz.utils.round(getResult(item.json.result),4) .. " kwH")
logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")" ,dz.LOG_ERROR)
logWrite(item.data)
}I amended the script to take the costs into account.pimseb wrote: Sunday 10 February 2019 19:48 Thank you waaren but it's not exactly what I'm trying to do
Your script returns an usage in Kwh and in fact I don't know what value it returns because it doesn't match any of the value of my smart P1 meter report
httpResponses = { httpResponses .. "*" }
logging = {
data = { energyCosts = { initial = {} }},
local function triggerJSON(url,delay, response)
dz.openURL({ url = url,
method = "GET",
callback = response }).afterSec(delay)
dz.notify("Yesterday's ", str)
local function setCosts(t)
dz.data.energyCosts.t1 = ( t.CostEnergy or 0 ) / 10000
dz.data.energyCosts.t2 = ( t.CostEnergyT2 or 0 ) / 10000
dz.data.energyCosts.r1 = ( t.CostEnergyR1 or 0 ) / 10000
dz.data.energyCosts.r2 = ( t.CostEnergyR2 or 0 ) / 10000
yesterdayTotal = rt[key].c1 * dz.data.energyCosts.t1 + rt[key].c3 * dz.data.energyCosts.t2 - rt[key].c2 * dz.data.energyCosts.r1 - rt[key].c4 * dz.data.energyCosts.r2
dayBeforeYesterdayTotal = rt[key].c1 * dz.data.energyCosts.t1 + rt[key].c3 * dz.data.energyCosts.t2 - rt[key].c2 * dz.data.energyCosts.r1 - rt[key].c4 * dz.data.energyCosts.r2
if dz.data.energyCosts.T1 == nil or day == 1 then
triggerJSON(dz.settings['Domoticz url'] .. "/json.htm?param=getcosts&type=command&idx=" .. energyDevice.id,0 , httpResponses .. "_cost")
triggerJSON(dz.settings['Domoticz url'] .. "/json.htm?range=year&sensor=counter&type=graph&idx=" .. energyDevice.id,10, httpResponses .. "_graph")
if item.trigger == httpResponses .. "_cost" then
setCosts(item.json)
showResult("elektricity Costs: ".. dz.utils.round(getResult(item.json.result),2) .. " Euro" )
logWrite(item.data)
http://domoticz_IP:domotic_port/json.htm?range=year&sensor=counter&type=graph&idx=<your energy device>
http://domoticz_IP:domotic_port/json.htm?param=getcosts&type=command&idx=<your energy device>Code: Select all
"c1" : "153.969",
"c2" : "0",
"c3" : "5569.362",
"c4" : "0",
"d" : "2019-02-09",
"r1" : "0.000",
"r2" : "0.000",
"v" : "26.169",
"v2" : "58.232"
"c1" : "180.503",
"c2" : "0",
"c3" : "5627.594",
"c4" : "0",
"d" : "2019-02-10",
"r1" : "0.000",
"r2" : "0.000",
"v" : "25.071",
"v2" : "48.292"
"d" : "2019-02-11",
"r1" : "0.000",
"r2" : "0.000",
"v" : "16.165",
"v2" : "12.377"
"status" : "OK",
"title" : "Graph counter year"
"CostEnergy" : 1102,
"CostEnergyR1" : 800,
"CostEnergyR2" : 800,
"CostEnergyT2" : 1430,
"CostGas" : 6218,
"CostWater" : 16473,
"CounterR1" : "0.000",
"CounterR2" : "0.000",
"CounterT1" : "222.104",
"CounterT2" : "5688.327",
"DividerWater" : 100.0,
"status" : "OK",
"title" : "GetElectraCosts"
If you do the math you will see that the script reports the correct cost. The GUI shows the costs for a day earlier. If you want the script to report that (in my opinion wrong) cost you can change lines 49 and 50 of attached scriptpimseb wrote: Monday 11 February 2019 10:17 json.htm?range=year&sensor=counter&type=graph&idx=7
Just parsing the last lines :
local yesterday = os.date("%Y-%m-%d",os.time()-2*24*60*60)
local dayBeforeYesterday = os.date("%Y-%m-%d",os.time()-3*24*60*60)Code: Select all
devices = { "XButton-2" },
logging = {
method = "GET",
dz.data.energyCosts.c1 = ( t.CostEnergy or 0 ) / 10000
dz.data.energyCosts.c3 = ( t.CostEnergyT2 or 0 ) / 10000
dz.data.energyCosts.c2 = ( t.CostEnergyR1 or 0 ) / 10000
dz.data.energyCosts.c4 = ( t.CostEnergyR2 or 0 ) / 10000
local longNames = {
c1 = "Low tariff consumed",
c2 = "High tariff delivered",
c3 = "High tariff consumed",
c4 = "Low tariff delivered"
local yesterdayTotal, dayBeforeYesterdayTotal, yesterdayKey, dayBeforeYesterdayKey
yesterdayKey = key
for meter, total in pairs(rt[key]) do
if meter:sub(1,1) == "c" then
logWrite(rt[key].d .. ": " .. longNames[meter] ..": Value ==>> " .. total .. " cost = " .. dz.utils.round((tonumber(total) or 0) * (dz.data.energyCosts[meter] or 1),2))
yesterdayTotal = rt[key].c1 * dz.data.energyCosts.c1 + rt[key].c3 * dz.data.energyCosts.c3 - rt[key].c2 * dz.data.energyCosts.c2 - rt[key].c4 * dz.data.energyCosts.c4
dayBeforeYesterdayKey = key
dayBeforeYesterdayTotal = rt[key].c1 * dz.data.energyCosts.c1 + rt[key].c3 * dz.data.energyCosts.c3 - rt[key].c2 * dz.data.energyCosts.c2 - rt[key].c4 * dz.data.energyCosts.c4
logWrite( "\n\n\t\t\t subtotals Costs: " .. longNames.c1 .. ": " .. dz.utils.round(rt[yesterdayKey].c1 * dz.data.energyCosts.c1 - rt[dayBeforeYesterdayKey].c1 * dz.data.energyCosts.c1,2) .. " Euro" ..
"\n\t\t\t subtotals Costs: " .. longNames.c2 .. ": " .. dz.utils.round(rt[yesterdayKey].c2 * dz.data.energyCosts.c2 - rt[dayBeforeYesterdayKey].c2 * dz.data.energyCosts.c2,2).. " Euro" ..
"\n\t\t\t subtotals Costs: " .. longNames.c3 .. ": " .. dz.utils.round(rt[yesterdayKey].c3 * dz.data.energyCosts.c3 - rt[dayBeforeYesterdayKey].c3 * dz.data.energyCosts.c3,2) .. " Euro" ..
"\n\t\t\t subtotals Costs: " .. longNames.c4 .. ": " .. dz.utils.round(rt[yesterdayKey].c4 * dz.data.energyCosts.c4 - rt[dayBeforeYesterdayKey].c4 * dz.data.energyCosts.c4,2) .. " Euro\n" )
local delay = 0
if dz.data.energyCosts.c1 == nil or day == 1 then
delay = 10
triggerJSON(dz.settings['Domoticz url'] .. "/json.htm?range=year&sensor=counter&type=graph&idx=" .. energyDevice.id,delay, httpResponses .. "_graph")
setCosts(item.json)
logWrite(item.data)
}Code: Select all
local dayBeforeYesterday = os.date("%Y-%m-%d",os.time()-3*24*60*60)Users browsing this forum: No registered users and 1 guest
