I'm using latest beta build of Dashticz, and I'm impressed with the dashboards I'm able to build with ease. But I'm facing a problem with my setpoint devices. How can I modify the default min temp of 12c and max temp of 25c? I'm not able to set the temp outside of this values. I would like to have min possible value set to 5 and the max possible value set to 35.
Thx
[SOLVED] Not able to adjust setpoint
Re: Not able to adjust setpoint
So, answering my own question
The setpoint min and max range is defined in the getThermostatBlock function in main.js.
change this line with your desired values
this.html += '<strong class="title input-number title-input" min="12" max="25" data-light="' + device['idx'] + '">' + this.title + '</strong>';Code: Select all
function getThermostatBlock(device, idx) {
this.html = '';
this.html += iconORimage(idx + '_1', '', 'heating.png', 'on icon', 'style="max-height:35px;"');
this.html += '<div class="col-xs-8 col-data">';
this.title = device['Data'] + _TEMP_SYMBOL;
this.value = device['Name'];
if (titleAndValueSwitch(idx + '_1')) {
this.title = device['Name'];
this.value = device['Data'] + _TEMP_SYMBOL;
this.html += '<strong class="title">' + this.title + '</strong><br />';
this.html += '<span class="state">' + this.value + '</span>';
if (showUpdateInformation(idx)) {
this.html += '<br /><span class="lastupdate">' + moment(device['LastUpdate']).format(settings['timeformat']) + '</span>';
this.html += '</div>';
$('div.block_' + idx + '_1').html(this.html);
this.html = '';
this.html += '<ul class="col-thermostat input-groupBtn">';
this.html += '<li class="up"><a href="javascript:void(0)" class="btn btn-number plus" data-type="plus" data-field="quant[' + device['idx'] + ']" onclick="this.blur();">';
this.html += '<em class="fas fa-plus fa-small fa-thermostat"></em>';
this.html += '</a></li>';
this.html += '<li class="down"><a href="javascript:void(0)" class="btn btn-number min" data-type="minus" data-field="quant[' + device['idx'] + ']" onclick="this.blur();">';
this.html += '<em class="fas fa-minus fa-small fa-thermostat"></em>';
this.html += '</ul>';
this.html += iconORimage(idx + '_2', '', 'heating.png', 'on icon iconheating', '', '2');
this.title = number_format(device['Data'], 1) + _TEMP_SYMBOL;
if (titleAndValueSwitch(idx) || titleAndValueSwitch(idx + '_2')) {
this.value = number_format(device['Data'], 1) + _TEMP_SYMBOL;
this.html += '<strong class="title input-number title-input" min="5" max="40" data-light="' + device['idx'] + '">' + this.title + '</strong>';
this.html += '<div class="state stateheating">' + this.value + '</div>';
$('div.block_' + idx + '_2').html(this.html);
$('div.block_' + idx).html(this.html);
if (typeof(addedThermostat[idx]) === 'undefined') {
addThermostatFunctions('.block_' + idx);
addedThermostat[idx] = true;
if (typeof(addedThermostat[idx + '_2']) === 'undefined') {
addThermostatFunctions('.block_' + idx + '_2');
addedThermostat[idx + '_2'] = true;
return [this.html, false];
}Re: Not able to adjust setpoint
Or even better, expose the min and max setpoint values as configurable parameters
modify main.js
add config to your CONFIG.js
modify main.js
this.html += '<strong class="title input-number title-input" min="' + settings['setpoint_min'] + '" max="' + settings['setpoint_max'] + '" data-light="' + device['idx'] + '">' + this.title + '</strong>';Code: Select all
config['setpoint_min'] = 5;
config['setpoint_max'] = 40;Who is online
