Geofencing with 2 persons? Family situation
Posted: Friday 08 February 2019 19:41
by Wilpshaar
Hi all, just registered and here my first post. I am using Domoticz on my synology nas and am playing around with my hue lamps etc, goes all fine..
Testing geofence now, looks OK but how to handle with a partner. My girlfriend?
If I go away and she stays at home the lights should stay remain on ofcourse and the heating normal..
I can nowhere find a how to? Installing domoticz app also on her phone with geofence on also?
But how is that to set in domoticz? Do I find 2 devices then?
I wish to prepare on a to buy thermostat etc and wish to experience geofencing with the lights etc
Looking forward to your reply,
Ger
Re: Geofencing with 2 persons? Family situation
Posted: Friday 08 February 2019 19:51
by DutchHans
Hi Ger...
Its simple... Make a dummyswitch ...call it Presence...then if you are at home. Update the dummy switch to "on"... if your girlfriend is at home ..update the dummy to "on".. if you are both away..update the dummy with "Off"..
This can be done in lua or blockly..
I could provide my script as a start if you like.
Cheers, Hans
Posted: Friday 08 February 2019 20:06
by poudenes
I'm using 2 dummy switches and the app (ios) locative to send http to change the status of de dummy. Works great for more then 2 years. Me and my friend have their own dummy switch so I build lot of dzvents around it. Never we get back in dark house or someone leaves and other sit in a dark house because lights go off.... Everything is possible....
Verzonden vanaf mijn iPhone met Tapatalk Pro
Posted: Friday 08 February 2019 21:07
by Wilpshaar
Thanks Hans and?.. I did successfully setup a dummy switch and found it also in blockly, that works sofar. But I will need to install the app as well on my girlfriends phone right? Then I can write blockly on both the switches, one for me and one for her right? 😬 Ofcourse her notifications must be disabled 😉 thanks guys sofar! Good weekend
Posted: Friday 08 February 2019 21:59
by Lebo2d9
I use presence detection based on Life360, every person has his own dummy switch
Posted: Friday 08 February 2019 22:50
by Wilpshaar
Hi Lebo, but domoticz app on each device needed yes? That is my question, thanks,
Ger
Posted: Saturday 09 February 2019 8:44
by Lebo2d9
The domoticz app is not needed on each device. You need the Life360 app on each device. On me domoticz server I have a script running every minute that is checking if someone is in our home circle. If there is someone in the circle the script put the dummy switch of that person to on.
The only "problem" you have with life360 is that very memeber of your circle can seen where everybody is.
kind regards
Koen
Posted: Monday 01 April 2019 8:03
by rinyheuvelman
DutchHans wrote: Friday 08 February 2019 19:51 Hi Ger...
Cheers, Hans
Thought it was simple too, but nevertheless everything I tried to get that dummy switch working failed. I have 3 dummy switches, turning on/off if phone is present. Can get it working: switching the "Presence" dummy on as soon as 1 phone switched on and of when no phones found
Posted: Wednesday 03 April 2019 14:38
by AllesVanZelf
Have your tried Presence detection in the wiki? link.
This works very well for me.
