Someone tested Livolo Zigbee switch with Zigate?
pfloryann
- Domoticz version: 2026.3
I want to buy Livolo Zigbee wall switch ( https://www.aliexpress.com/store/produc ... 90067.html ) and i wish to know if someone tested this switch with ZIGATE.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Re: Someone tested Livolo Zigbee switch with Zigate?
Looking at the following site it is not easy to get these switches connected as they use specific settings. https://github.com/Koenkk/zigbee2mqtt/issues/592
But on another domotica application (Jeedom) Zigate Plugin someone is working on it but my french is a little bit rusty
: https://github.com/KiwiHC16/Abeille/issues/570
From the french, this seems working with the Zigate. So just an integration with the plugin, might be needed.
Come back to me when you get it, I'll let you know how to proceed
Test and Implementation in progress see https://github.com/sasu-drooz/Domoticz- ... issues/337
Volonteers to help and support us, you are more than welcome.
Just switch to branch pre-4.1 , you have an initial implementation of Livolo support
pfloryann
Hi...Right now i tested the livolo zigbee switch with 1 touch button i used 4.0 plugin :
2019-02-20 21:02:32.451 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 4c08 with Data : 6d4c0801040600000018000101
This is the message from domoticz log
pfloryann
I'm webdeveloper and i didn't work with hardware programing yet but i want to help you if i can and you explain to me how.pipiche wrote: Sunday 17 February 2019 12:59 Volonteers to help and support us, you are more than welcome.
Will be creating a dedicated branch for livolo. Stay tuned
You can switch to the livolo branch, by doing:
- git pull
- git checkout livolo
then , you'll have to remove the livolo from the Domoticz/Plugin , in order to re-pair and re-create the widgets
Commands should work, but they are several issues:
- it looks that after a while the livolo get disconnected from the Zigate (nothing to do with the plugin )
- To get status is where we are working now
- git pull
- Thuis
Tunedpipiche wrote: Wednesday 20 February 2019 20:46 Will be creating a dedicated branch for livolo. Stay tuned
Fun for everyone!
Christo99
I didn’t realize they also made a zigbee model. Based on reports in other forums, though, it is using a proprietary profile and probably will not work with SmartThings. People are reporting that it only works with its own gateway cleanmaster.
It has been reported to the Zigate developpers as the Livolo switchs can be paired and can work , but after few minutes they got removed from the Zigbee network.
https://github.com/fairecasoimeme/ZiGate/issues/148
It works too with zigbee2mqtt with some tricks.Christo99 wrote: Thursday 04 April 2019 13:36 I didn’t realize they also made a zigbee model. Based on reports in other forums, though, it is using a proprietary profile and probably will not work with SmartThings. People are reporting that it only works with its own gateway cleanmaster.
Looking at the tricks and the implication, I would simply stay away from that switch , or just use their Hub
