Hi fellow Domoticz-fans!
In its switch log I see the Xiaomi RGB gateway switching off at irregular intervals. In the general log I see that this always coincides with a signal from the Xiaomi Gateway Lux sensor. It's almost as if the built-in ambient light sensor somehow triggers the RGB gateway to be switched off.
So I covered the Gateway with the original box and geuss what, in the darkness the irregular off-switches dissappeared.
So every time the ambient light level changes the RGB gateway switches off!
I don't know if this behaviour is triggered by the gateway or by Domoticz. I also don't know if it is a bug or a feature....
Does anybody recognize this behaviour and does someone know how to solve this?
Xiaomi RGB gateway keeps switching off
bldewit
- Domoticz version: Stable
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
Rex100
Re: Xiaomi RGB gateway keeps switching off
I have noticed the same, but I think it is related to Domoticz, since when I used the gatewayt under Xiaomi Mi server it didn't happen.
Don't know is it a bug or a feature, but would like to get rid of that function.
Any ideas ?
Any ideas ?
