RFLink Help
fellovertoday
RFLink Help
Post by fellovertoday »
Hello all,
I have been trying to build an RFLink gateway following the instructions here:
https://diyprojects.io/gateway-rflink-r ... Emzf1X7SUk
I believe I have built correctly, but I am not able to find any devices in Domoticz. I have tried on both a Raspberry Pi and Synology without any luck.
I have spent some time on this and suspect it is probably quite simple, I was wondering if anyone would be so kind as to look what I have built and suggest where I have gone wrong. I haven't done anything like this before (which I expect is apparent):
mf76130
Re: RFLink Help
Post by mf76130 »
Did you flash a firmware on the device?
Did you test it in windows with rflinkloader?
did you add the device in domoticz and is it showing a version like that one?
fellovertoday
Re: RFLink Help
Hi yes I did thanks
freijn
Domoticz version: Stable
Re: RFLink Help
Post by freijn »
is this one of those SUPER cheap 433 receiver and transmitters ? I have never managed to get the timing working.
Ended up in buying an already build one.
There are libraries you can load and have a monitor showing the signales you receive, With the same button press I received different results
every time pressing the button. (sorry)
fellovertoday
Re: RFLink Help
Yes super cheap but I waited a long time so I deserve better!
