global function
pvklink
Domoticz version: latest b
global function
Post by pvklink »
The snapshot function (made by @waaren) works great!
I like to use this function in more scripts.
Is there a way to make this function 'global' so that i can use this function more times without cut and paste the function in every script?
Like putting this function in a special named dzvents script that functions as a library?
	on = {devices = {'Neemfoto'}},
    logging =   { level   = domoticz.LOG_DEBUG ,                  -- Uncomment to override the dzVents global logging setting
                  marker  = "Security"},
    execute = function(dz, device, info)
local function snapshot(idx,subject,delay)
    if not dz then dz = domoticz end
    if not idx then idx = 1 end
    if not subject then
        subject = "snapshot_" .. dz.time.rawDate .. "_" .. dz.time.rawTime
        subject = subject .. "_" .. dz.time.rawDate .. "_" .. dz.time.rawTime
    if delay and delay > 0 then
        local url = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=emailcamerasnapshot&camidx=".. idx .. "&subject=" .. dz.utils.urlEncode(subject)
        dz.openURL(url).afterSec(delay)
        dz.sendCommand("SendCamera:" .. idx, subject)
local cameraID  = 1
local cameraNAME  = 'pvkcam'
local repeats   = 1  --- number of repeats
local interval  = 1  -- seconds between repeats
for i = 0,(repeats - 1) do
    snapshot(cameraID,"Foto (" .. i+1 .."/" ..  repeats .. ") van camera (" .. cameraNAME ..
                        "). Foto is gemaakt ".. (i * interval) ..  " seconden na eerste foto ", ( i * interval ))
Jablotron connection, Ikea
Re: global function
pvklink wrote: Wednesday 23 January 2019 10:08 I like to use this snapshot dzVents function in more scripts.
Yes, that is possible (see the shared helper section of dzVents wiki) .
Happy to make an example but today a native dzVents snapshot command was merged into development. So starting Domoticz V4.10363 you can use domoticz.snapshot with the option .afterHour(hours), .afterMin(minutes), .afterSec(seconds), withinHour(hours), withinMin(minutes) or withinSec(seconds)
With this I think it is no longer needed to have this as a global helper function.
Please comment if you think otherwise.
pvklink
Re: global function
Post by pvklink »
Great!
I wait for that! (and just installed the latest domoticz)
now examine how to call this new function and what to change in my script.
part 1 is to remove the old function of my script...
part 2 is to add new parameters
local cameraID  = 1
Just installed my spirit zwave radiator valve, worked within 5 minutes. But have some questions. Can i open a topic in dzvents or is it better to use another part of the board?
I saw that you offered an other user to help with this valve and and dzvents, he didn't responped.
I would have some help
Re: global function
pvklink wrote: Wednesday 23 January 2019 11:32 Now examine how to call this new function and what to change in my script.
Change
to
    dz.snapshot(cameraID,"Foto (" .. i+1 .."/" ..  repeats .. ") van camera (" .. cameraNAME ..
                        "). Foto is gemaakt ".. (i * interval) ..  " seconden na eerste foto ").afterSec( i * interval )
pvklink
Re: global function
Post by pvklink »
Works!
