(rooted) Toon thermostat combined Get and Set script
Posted: Wednesday 23 January 2019 1:45
Created for one of the Dutch forum members who experienced a problem with the two Lua scripts controlling the communication between a rooted Toon and domoticz after updating to a recent domoticz version. This script uses the same uservariables as the original Lua script. many thanks to @johan1974 for testing, patience and constructive feedback.
When switching from the Lua version to this one. Make sure you deactivate both Lua scripts and remove the actions from the selector switches.
- uservariables used in this script
- UV_ToonIP ............................................. -- Toon IP address
- UV_ToonThermostatSensorName ................... -- virtual thermostat setpoint showing current setpoint
- UV_ToonTemperatureSensorName .................. -- virtual temperature sensor showing current room temperature
- UV_ToonScenesSensorName ......................... -- virtual selector switch showing current program
- UV_ToonAutoProgramSensorName .................. -- virtual selector switch showing current auto program status
- UV_ToonProgramInformationSensorName ......... -- virtual text sensor showing displaying program information status
Sync Domoticz sensors / switches with rooted Toon in case the value is changed on the physical device.
Updates
Thermostat Sensor
Temperature Sensor
Scenes switch based on program set on Toon
(Auto)program switch to value set on Toon
Program information text to value set on Toon
local toonResponse = "toonResponse"
local ResponseOK = "OK_toon_Response"
local scriptVersion = "version 0.117"
on = { timer = { "every minute" },
devices = { "Toon Thermostaat","Toon Scenes" },
httpResponses = { toonResponse , ResponseOK }},
logging = {
level = domoticz.LOG_DEBUG,
marker = scriptVersion .. " Toon"
data = {
lastActive = { initial = 0 },
isActive = { initial = false },
blockSetPoint = { initial = false }, -- Bug in TimedCommands (silent() does not work in updateSetPoint
execute = function(dz, item)
local now = os.time(os.date('*t')) -- seconds since 1/1/1970 00:00:01
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function sendURL(url,callback)
local toonIP = dz.variables("UV_ToonIP").value
local url = "http://" .. toonIP .. url
dz.openURL({
url = url,
method = "GET",
callback = callback
local function setSetPoint(device,setPoint) -- update setPoint
if device.setPoint ~= setPoint then
logWrite("Updating thermostat sensor to new set point: " .. setPoint )
device.updateSetPoint(setPoint)
dz.data.blockSetPoint = false
local function setSelector(device,state,str) -- update selector
if device.level ~= state and device.lastUpdate.secondsAgo > 59 then
logWrite("Updating the " .. device.name .. " level to " .. str .. " (" .. state .. ")")
device.switchSelector(state).silent()
local function setTemperature(device,temperature) -- Update temperature sensor
if device.temperature ~= temperature then
logWrite("Updating the temperature sensor to: " .. temperature)
device.updateTemperature(temperature).silent()
local function setText(device,text) -- Update text sensor
if device.text ~= text then
logWrite("Updating " .. device.name .. " to: " .. text)
device.updateText(text)
local function setSetPointInfo(device,nextTime,setPoint)
if nextTime == 0 or setPoint == 0 then
newText = "Op " .. setPoint .. "°"
newText = "Om " ..os.date("%H:%M", nextTime).. " naar " .. setPoint .. "°"
setText(device,newText)
local function setSceneState(device,state)
local states = { 50,40,30,20,10} -- Manual, Comfort, Home, Sleep , Away
local stateStrings = { "Manual", "Comfort", "Home", "Sleep" , "Away"}
local newState = states[state + 2]
local stateString = stateStrings[state + 2]
setSelector(device,newState,stateString)
local function setProgramState(device,state)
local states = { 10,20,30 } -- No, Yes, Temporary
local stateStrings = { "No", "Yes", "Temporary" }
local newState = states[state + 1]
local stateString = stateStrings[state + 1]
local function updateDevices(rt)
local toonThermostat = dz.devices(dz.variables("UV_ToonThermostatSensorName").value) -- Sensor showing current setpoint
local toonTemperature = dz.devices(dz.variables("UV_ToonTemperatureSensorName").value) -- Sensor showing current room temperature
local toonScenes = dz.devices(dz.variables("UV_ToonScenesSensorName").value) -- Sensor showing current program
local toonAutoProgram = dz.devices(dz.variables("UV_ToonAutoProgramSensorName").value) -- Sensor showing current auto program status
local toonProgramInformation = dz.devices(dz.variables("UV_ToonProgramInformationSensorName").value) -- Sensor showing displaying program information status
setSetPoint (toonThermostat, dz.utils.round(rt.currentSetpoint / 100,1 ))
setTemperature (toonTemperature, dz.utils.round(rt.currentTemp / 100,1 ))
setSceneState (toonScenes, rt.activeState ) -- "activeState":"-1" ==> 50
setProgramState (toonAutoProgram, rt.programState ) -- "programState":"0" ==> 10
setText (toonProgramInformation, dz.utils.round(rt.nextTime,rt.nextSetpoint / 100,1 ))
local function procesToonResponse()
logWrite(tostring(item.data))
return dz.utils.fromJSON(item.data)
local function sendSetPoint(newSetPoint)
logWrite("In function sendSetPoint; " .. item.name .. " wants to set setPoint to " .. newSetPoint)
local calculatedSetPoint = newSetPoint * 100
local urlString = "/happ_thermstat?action=setSetpoint&Setpoint=" .. calculatedSetPoint
if not dz.data.blockSetPoint then
sendURL(urlString, ResponseOK )
logWrite("Toon setPoint send using " .. urlString)
logWrite("Toon setPoint not send ; unblocking now ")
local function sendScene()
local newstate
logWrite("In function sendScene; " .. item.name .. "; level " .. item.level .. " ==>> " .. item.levelName)
if item.level == 0 then -- Off
sendSetPoint(60)
return
if item.level == 10 then newState = 3 -- Away
elseif item.level == 20 then newState = 2 -- Sleep
elseif item.level == 30 then newState = 1 -- Home
elseif item.level == 40 then newState = 0 -- Comfort
else newState = -1 -- Invalid
local urlString = "/happ_thermstat?action=changeSchemeState&state=2&temperatureState=" .. newState
logWrite("Toon SchemeState send using " .. urlString)
local function getInfo()
sendURL("/happ_thermstat?action=getThermostatInfo",toonResponse)
-- Check for conflicts between timer and set Toon
local function setActive(state)
if state then
logWrite("Triggered by device. Setting active")
dz.data.isActive = true
dz.data.lastActive = now
dz.data.isActive = false
logWrite("Answer from Toon. Unset active")
local function isFree()
return (( dz.data.lastActive + 90 ) < now ) or ( not dz.data.isActive )
local function writeStatus(origin)
logWrite(origin .. "isFree: " .. tostring(isFree()))
logWrite(origin .. "lastActive: " .. os.date("%X",dz.data.lastActive))
logWrite(origin .. "blockSetPoint: " .. tostring(dz.data.blockSetPoint))
-- main program
writeStatus("-- start -- ")
if item.isDevice then -- triggered by selector or setPoint
if item.name == "Toon Scenes" then
sendScene()
setActive(true)
sendSetPoint(item.setPoint)
setActive(true)
elseif item.isTimer and isFree() then -- triggered by timer
dz.data.blockSetPoint = true
getInfo()
elseif item.isHTTPResponse then -- Triggered by Toon response
if item.trigger == toonResponse then -- return from getInfo()
if item.ok and isFree() then -- statusCode == 2xx
updateDevices(procesToonResponse())
elseif isFree() then
logWrite("Toon did not return valid data. Please check what went wrong. Error code: " .. item.statusCode or 999 ,dz.LOG_ERROR)
logWrite("Invalid data: " .. tostring(item.data))
logWrite("Toon is busy dealing with sendScene or sendSetPoint")
logWrite("returned from sendScene or sendSetPoint: " .. tostring(item.data))
setActive(false)
logWrite("This should never happen")
writeStatus("-- end -- ")
