Moving ha bridge to a new pc.
Posted: Monday 21 January 2019 20:20
by sion
Hi all.
I am in the process of tidying up my setup and consolidating some of the boxes I have running. To help with this I would like to move ha bridge to a new pc.
It’s currently on a windows pc, and the new one will also be windows.
If I backup and restore onto the new pc, and make sure the new pc has the same IP and port as the old one, will it just work? Or will I have to re-add all my devices to Alexa.
Has anyone done this?
Thanks.
Sion.
Re: Moving ha bridge to a new pc.
Posted: Tuesday 22 January 2019 12:03
by philchillbill
Should work directly, provided you copy over the config and device.db file from the old install. Both are just json data that you can see and edit in a decent text editor. If anything changes in your setup, search and replace in an editor is usually easier than in the HA-Bridge UI.
