Moving ha bridge to a new pc.
Alexa, Google Home and Siri
sion
Post by sion »
Hi all.
I am in the process of tidying up my setup and consolidating some of the boxes I have running. To help with this I would like to move ha bridge to a new pc.
It’s currently on a windows pc, and the new one will also be windows.
If I backup and restore onto the new pc, and make sure the new pc has the same IP and port as the old one, will it just work? Or will I have to re-add all my devices to Alexa.
Has anyone done this?
Thanks.
Sion.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
philchillbill
Re: Moving ha bridge to a new pc.
Post by philchillbill »
Should work directly, provided you copy over the config and device.db file from the old install. Both are just json data that you can see and edit in a decent text editor. If anything changes in your setup, search and replace in an editor is usually easier than in the HA-Bridge UI.
