Set dimmer on 100% when swiched on
Chillertje
Post by Chillertje »
I'm using a Zwave Dimmer (Duwi) to control one of my lights.
When somebody turn on the lights, I would like to have the dimmer set to 100 by default.
I'm using a DzVents script that triggers if the switch is turned on.
For some reason this isn't working. When I use DimTo(100), the lights are automatically turned on again when I Turn off the wall switch or the virual dimmer. This means I'm not able to turn off the lights.
Therefor I created a DZVents script to set the value of the dimmer to 100, when I switch the lights off.
This is also not working and the lights are automatically turned on again.
Does anybody have an idea?
		devices = {
			1890
	 if (device.state == "Off") then
        device.dimTo(100).silent()
	    device.switchOff().afterSec(1).silent()
