WIKI: domoticz.notify ?  [Solved]
Varazir
Post by Varazir »
Hello
I have looked at the wiki for DzVents and can't find how domoticz.notify works.
I like to send a custom http action notification.
TIA
Daniel
Re: WIKI: domoticz.notify ?
Varazir wrote: Friday 18 January 2019 16:46 Hello
TIA
Daniel
notify in dzVents:
notify(subject, message, priority, sound, extra, subsystem): Function. Send a notification (like Prowl). Priority can be like domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY. For sound see the SOUND constants below. subsystem can be a table containing one or more notification subsystems. See domoticz.NSS_xxx types.
so for http use domoticz.NSS_HTTP as notification subsystem. What the HTTP notification does is defined in the domoticz settings -> notifications page and not controlled by dzVents.
Varazir
Post by Varazir »
waaren wrote: Friday 18 January 2019 21:22
TIA
Daniel
notify in dzVents:
So domoticz.NSS_HTTP('subject', 'message') should work?
Varazir wrote: Friday 18 January 2019 23:54 So domoticz.NSS_HTTP('subject', 'message') should work?
No.
syntax is notify(subject, message, priority, sound, extra, subsystem)
so you should use something like
domoticz.notify("subject","message", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_HTTP)
Varazir
Post by Varazir »
waaren wrote: Saturday 19 January 2019 0:01
No.
When you say it you are ofc right :)
Thanks will try
Varazir
Post by Varazir »
No.
I get this
2019-01-24 07:26:41.700 Status: dzVents: Error (2.4.10): LightControl: An error occured when calling event handler Detection
2019-01-24 07:26:41.700 Status: dzVents: Error (2.4.10): LightControl: ...domoticz/scripts/dzVents/generated_scripts/Detection.lua:84: attempt to index global 'domoticz' (a nil value)
domoticz.notify("IKEA Hallen","Stänger av Lamporna i hallen", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_HTTP)
Re: WIKI: domoticz.notify ?  [Solved]
Varazir wrote: Thursday 24 January 2019 10:23
No.
I get this
If you look at your script you will see a line starting with execute = function(
The first parameter in this line is the reference to the domoticz object with all devices, variables, constants, etc..
You can give it any valid name (also called identifier) In Lua and dzVents a name can be any string of letters, digits, and underscores, not beginning with a digit and not one of the reserved words (and, break, do, else, elseif, end, false, for, function, if, in,local, nil, not, or, repeat, return, then, true, until, while)
So if you use domoticz as name you can reference any sub object in the domoticz object using that name followed by a dot "domoticz."
for example domoticz.devices() , domoticz.log, etc
If you choose dz as name you must use that so it would become dz.devices() dz.log, etc.
in your example is would become
dz.notify("IKEA Hallen","Stänger av Lamporna i hallen", dz.PRIORITY_NORMAL,nil,nil,dz.NSS_HTTP)
Hope this clarifies
