Water leak script (Blockly to dzVents)
Posted: Friday 11 January 2019 18:37
by QSKONE
Hi , I try convert every my blockly scripts to dzVents and it is successful. Excluding one - simple water leak script. Problem is water leak from dzVents script cannot switch on any device. Why? What is wrong? Thanks
on = { devices = { 8 }}, --- xiaomi water leak
execute = function(dz, item )
waterleak = dz.devices( 8 ).state --- xiaomi water leak
gateway = dz.devices( 1 ).state --- xiaomi gateway rgb
alarm = dz.devices( 2 ).selector --- alarm ringtone state
hue = dz.devices( 31 ).selector --- mi gateway hue
brightnes = dz.devices( 32 ).selector --- mi gateway bri
if dz.devices( 8 ).state == "0n" then
dz.devices( 1 ).switchOn().forMin (1)
dz.devices( 2 ).switchSelector(10).forMin(1)
dz.devices( 31 ).switchSelector(100)
dz.devices( 32 ).switchSelector(100)
Re: Water leak script (Blockly to dzVents)
Posted: Friday 11 January 2019 18:43
by waaren
QSKONE wrote: Friday 11 January 2019 18:37
Without the log it is hard to say but my first guess is this line.
Maybe better to change is in something like
dz.devices( 2 ).switchSelector(dz.devices(2).level).afterMin(1)
Posted: Friday 11 January 2019 18:56
by QSKONE
@waaren
Script start ok
2019-01-11 18:51:22.302 Status: dzVents: Info: Handling events for: "Xiaomi Water Leak Detector", value: "On"
2019-01-11 18:51:22.309 Status: dzVents: Info: ------ Start internal script: Water leak dzVents: Device: "Xiaomi Water Leak Detector (Xiaomi Gateway)", Index: 8
2019-01-11 18:51:22.332 Status: dzVents: Info: ------ Finished Water leak dzVents
When i try simple example
if dz.devices(water leak sensor).state == 'On' then
dz.devices(any light).switchOn()
Light Will Not Turned On
Posted: Friday 11 January 2019 19:03
by waaren
QSKONE wrote: Friday 11 January 2019 18:56
@waaren
Script start ok
When i try simple
Your last code snippet will definitely not work.
will always nil or an error. Try
dz.devices("water leak sensor").state
Posted: Friday 11 January 2019 19:26
by QSKONE
Script with device 8 - water leak sensor works
execute = function(dz)
light = dz.devices( 76 ).state --- shelly 1.1
if dz.devices( 8 ).state == 'On' then
dz.devices( 76 ).switchOn()
When I change water leak sensor for xiaomi button script works too
on = { devices = { 90 }}, ---xiaomi button 3 idx 90
button = dz.devices( 90 ).state --- xiaomi button
if dz.devices( 90 ).state == "Click" then
But water leak script with water leak sensor still dont work. Any ideas?
Posted: Friday 11 January 2019 19:46
by QSKONE
Posted: Friday 11 January 2019 21:26
by waaren
QSKONE wrote: Friday 11 January 2019 19:46---
Can you try with this one. It will produce some extra loglines that might help in finding what the problem is. Also changed selector to level as selector is not a valid attribute
logging = {
level = domoticz.LOG_DEBUG,
marker = "waterLeak"
execute = function(dz, item)
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local xWaterleak = item --- xiaomi water leak
local xButton = dz.devices( 90 ) --- xiaomi button
local xGateway = dz.devices( 1 ) --- xiaomi gateway rgb
local xAlarm = dz.devices( 2 ) --- alarm ringtone state
local xHue = dz.devices( 31 ) --- mi gateway hue
local xBrightnes = dz.devices( 32 ) --- mi gateway bri
local button = xButton.state
local waterleak = xWaterleak.state
local gateway = xGateway.state
local alarm = xAlarm.level
local hue = xHue.level
local brightnes = xBrightnes.level
logWrite("State of ".. xWaterleak.name .. " is " .. waterleak)
logWrite("State of ".. xGateway.name .. " is " .. gateway)
logWrite("level of ".. xAlarm.name .. " is " .. alarm)
logWrite("level of ".. xHue.name .. " is " .. hue)
logWrite("level of ".. xBrightnes.name .. " is " .. brightnes)
if waterleak == "On" then
xGateway.switchOn().forMin (1)
xAlarm.switchSelector(10).forMin(1)
xHue.switchSelector(100)
xBrightnes.switchSelector(100)
Posted: Saturday 12 January 2019 12:04
by QSKONE
@waaren thank you for help ,inspiration and patience. Your last script work but it is huge. I rewrote completely script to tiny version.
active = true,
devices = {
'Xiaomi Water Leak Detector'
if dz.devices( 'Xiaomi Water Leak Detector' ).state == 'On' then
dz.devices('Xiaomi Gateway RGB').switchSelector(100)
dz.devices('Xiaomi Gateway RGB').setRGB(255, 0, 0)
dz.devices('Xiaomi Gateway Alarm Ringtone').switchSelector(10).forMin(1)
Video:
https://youtu.be/hCZC_APVWzo
Everything works fine ,but in log have this error.
Error: Error opening url: http://127.0.0.1:8080/json.htm?param=setcolbrightnessvalue&type=command&idx=1&hue=0&brightness=100&iswhite=false
I do not understand because I do not use 127.0.0.1 anywhere.
Re: Water leak script (Blockly to dzVents) [Solved]
Posted: Saturday 12 January 2019 12:21
by waaren
QSKONE wrote: Saturday 12 January 2019 12:04
active = true,
devices = {
Video:
I specifically wrote the extra lines to help you investigating what's happening during the execution of the script. So hopefully that was useful for you to get to a working version.
the Error about 127.0.0.1 is a classic. Please read the wiki and start with
Using dzVents with Domoticz , where you will read:
Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz.
Posted: Monday 14 January 2019 20:46
by waaren
Mayki wrote: Monday 14 January 2019 20:24
Is it possible to control multiple Xiaomi Water Leak Detector with one script?
Xiaomi Water Leak Detector and Xiaomi Water Leak Detector 2 etc.
Yes. See below
active = true,
devices = {
'Xiaomi Water Leak Detector',
'Xiaomi Water Leak Detector 2',
'Xiaomi Water Leak Detector 3',
if item.state == 'On' then
dz.notify("Water leakage", item.name, dz.PRIORITY_EMERGENCY)
