Water leak script (Blockly to dzVents)  [Solved]
QSKONE
Post by QSKONE »
Hi , I try convert every my blockly scripts to dzVents and it is successful. Excluding one - simple water leak script. Problem is water leak from dzVents script cannot switch on any device. Why? What is wrong? Thanks
   on = { devices = { 8 }},                                                      --- xiaomi water leak
   execute = function(dz, item )
      waterleak                = dz.devices( 8 ).state                          --- xiaomi water leak
      gateway                  = dz.devices( 1 ).state                          --- xiaomi gateway rgb
      alarm                    = dz.devices( 2 ).selector                       --- alarm ringtone state
      hue                      = dz.devices( 31 ).selector                      --- mi gateway hue
      brightnes                = dz.devices( 32 ).selector                      --- mi gateway bri
        if dz.devices( 8 ).state == "0n" then
             dz.devices( 1 ).switchOn().forMin (1)
             dz.devices( 2 ).switchSelector(10).forMin(1)
             dz.devices( 31 ).switchSelector(100)
             dz.devices( 32 ).switchSelector(100)
Re: Water leak script (Blockly to dzVents)
QSKONE wrote: Friday 11 January 2019 18:37 Hi , I try convert every my blockly scripts to dzVents and it is successful. Excluding one - simple water leak script. Problem is water leak from dzVents script cannot switch on any device. Why? What is wrong? Thanks
Without the log it is hard to say but my first guess is this line.
Maybe better to change is in something like
dz.devices( 2 ).switchSelector(dz.devices(2).level).afterMin(1)
QSKONE
Post by QSKONE »
@waaren
Script start ok
2019-01-11 18:51:22.302 Status: dzVents: Info: Handling events for: "Xiaomi Water Leak Detector", value: "On"
2019-01-11 18:51:22.309 Status: dzVents: Info: ------ Start internal script: Water leak dzVents: Device: "Xiaomi Water Leak Detector (Xiaomi Gateway)", Index: 8
2019-01-11 18:51:22.332 Status: dzVents: Info: ------ Finished Water leak dzVents
When i try simple example
    if dz.devices(water leak sensor).state == 'On' then
            dz.devices(any light).switchOn()
Light Will Not Turned On
QSKONE wrote: Friday 11 January 2019 18:56 @waaren
Script start ok
When i try simple
Your last code snippet will definitely not work.
will always nil or an error. Try
dz.devices("water leak sensor").state
QSKONE
Post by QSKONE »
Script with device 8 - water leak sensor works
    execute = function(dz)
       light                    = dz.devices( 76 ).state                         --- shelly 1.1
    if dz.devices( 8 ).state == 'On' then
            dz.devices( 76 ).switchOn()
When I change water leak sensor for xiaomi button script works too
   on = { devices = { 90 }},                                                    ---xiaomi button 3 idx 90
      button                   = dz.devices( 90 ).state                         --- xiaomi button
        if dz.devices( 90 ).state == "Click" then
But water leak script with water leak sensor still dont work. Any ideas?
QSKONE
Post by QSKONE »
QSKONE wrote: Friday 11 January 2019 19:46---
Can you try with this one. It will produce some extra loglines that might help in finding what the problem is. Also changed selector to level as selector is not a valid attribute
  logging   =   {
                            level       =       domoticz.LOG_DEBUG,
                            marker      =       "waterLeak"
    execute = function(dz, item)
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local xWaterleak     = item                               --- xiaomi water leak
        local xButton        = dz.devices( 90 )                   --- xiaomi button
        local xGateway       = dz.devices( 1 )                    --- xiaomi gateway rgb
        local xAlarm         = dz.devices( 2 )                    --- alarm ringtone state
        local xHue           = dz.devices( 31 )                   --- mi gateway hue
        local xBrightnes     = dz.devices( 32 )                   --- mi gateway bri
        local button         = xButton.state
        local waterleak      = xWaterleak.state
        local gateway        = xGateway.state
        local alarm          = xAlarm.level
        local hue            = xHue.level
        local brightnes      = xBrightnes.level
        logWrite("State of ".. xWaterleak.name .. " is " .. waterleak)
        logWrite("State of ".. xGateway.name ..   " is " .. gateway)
        logWrite("level of ".. xAlarm.name ..     " is " .. alarm)
        logWrite("level of ".. xHue.name ..       " is " .. hue)
        logWrite("level of ".. xBrightnes.name .. " is " .. brightnes)
        if waterleak == "On" then
             xGateway.switchOn().forMin (1)
             xAlarm.switchSelector(10).forMin(1)
             xHue.switchSelector(100)
             xBrightnes.switchSelector(100)
QSKONE
Post by QSKONE »
@waaren thank you for help ,inspiration and patience. Your last script work but it is huge. I rewrote completely script to tiny version.
    active = true,
        devices = {
            'Xiaomi Water Leak Detector'
    if dz.devices( 'Xiaomi Water Leak Detector' ).state == 'On' then
        dz.devices('Xiaomi Gateway RGB').switchSelector(100)
        dz.devices('Xiaomi Gateway RGB').setRGB(255, 0, 0)
        dz.devices('Xiaomi Gateway Alarm Ringtone').switchSelector(10).forMin(1)
Video: https://youtu.be/hCZC_APVWzo
Everything works fine ,but in log have this error.
 Error: Error opening url: http://127.0.0.1:8080/json.htm?param=setcolbrightnessvalue&type=command&idx=1&hue=0&brightness=100&iswhite=false
I do not understand because I do not use 127.0.0.1 anywhere.
Re: Water leak script (Blockly to dzVents)  [Solved]
QSKONE wrote: Saturday 12 January 2019 12:04 @waaren thank you for help ,inspiration and patience. Your last script work but it is huge. I rewrote completely script to tiny version.
    active = true,
        devices = {
I specifically wrote the extra lines to help you investigating what's happening during the execution of the script. So hopefully that was useful for you to get to a working version.
the Error about 127.0.0.1 is a classic. Please read the wiki and start with Using dzVents with Domoticz , where you will read:
Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz.
Mayki wrote: Monday 14 January 2019 20:24 Is it possible to control multiple Xiaomi Water Leak Detector with one script?
Xiaomi Water Leak Detector and Xiaomi Water Leak Detector 2 etc.
Yes. See below
    active = true,
        devices = {
                         'Xiaomi Water Leak Detector',
                         'Xiaomi Water Leak Detector 2',
                         'Xiaomi Water Leak Detector 3',
    if item.state == 'On' then
        dz.notify("Water leakage", item.name, dz.PRIORITY_EMERGENCY)
