Offset Gas counter
Posted: Thursday 10 January 2019 19:33
by Knibor
Hi, i have a P1 meter (slimme meter) And I can readout the "Gas" counter in Domoticz
Is it possible to copy the counter reading to another Virtual "managed" counter that has the possibility set an "offset"
Re: Offset Gas counter
Posted: Thursday 10 January 2019 20:35
by waaren
Knibor wrote: Thursday 10 January 2019 19:33 Hi, i have a P1 meter (slimme meter) And I can readout the "Gas" counter in Domoticz
The dzVents script below does just that but to a virtual Gas meter. The offset is set in the script body and the new value will be set when your P1 gas device is updated.
-- gasOffset
    on      =   {
                    devices         =   { "Gas"},        -- name of your real Gas devce
    logging =   {
                    level     =   domoticz.LOG_DEBUG,
                    marker    =   "gasOffset"
    execute = function(dz, item)
        local offset     = 123456                        -- Offset in dm3 (liters)
        local managedGas = dz.devices(1292)              -- id of device with offset
        managedGas.updateGas(item.counter * 1000 + offset)
Posted: Friday 11 January 2019 21:17
by Knibor
Waaren, thanks for the code.
Now I can reset the gasmeter when I get the energy bill.
Now I tried to calculate the Total cost in a year " Totaalkosten" this is the sum of the custom devices "Gaskosten" - "StroomOpbrengst"
I tried this dzVents code...but probably I do something wrong? It did't work.
on = { timer = { "every 5 minutes" }},
execute = function(dz)
-- Devices
local StroomOpbrengst = dz.devices('Stroom Opbrengst')
local Gaskosten = dz.devices('Gaskosten')
local Totaalkosten = dz.devices('Totaalkosten')
-- Kosten berekenen
local kosten = tonumber(dz.utils(Gaskosten - StroomOpbrengst))
-- Kosten updaten
Totaalkosten.updateCustomSensor(kosten)
Can you help me with this.
Posted: Friday 11 January 2019 22:15
by waaren
Knibor wrote: Friday 11 January 2019 21:17 Now I tried to calculate the Total cost in a year " Totaalkosten" this is the sum of the custom devices "Gaskosten" - "StroomOpbrengst"
        -- Devices
        -- Kosten berekenen
        -- Kosten updaten
Hi Knibor. "it does not work" is a bit too general. Most of the time when new code does not work you can get information on why it is not working in the domoticz logfile. In this case you try to subtract one device from another. What you want is do some calculation with device attributes.
And please enclose your code in code tags [ code] [/ code] (without the spaces). Can you try the code below ?
    on = { timer   = { "every 1 minutes" }},
    logging   =     {
                            marker      =       "total Cost"
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        -- Custom sensors store values in sValue field (string)
        -- Money
        local StroomOpbrengst   = dz.devices('Stroom Opbrengst').state
        local Gaskosten         = dz.devices('Gaskosten').state
        -- Device
        -- Kosten berekenen
        local kosten      = tonumber(Gaskosten) - tonumber(StroomOpbrengst)
        logWrite("Kosten zijn: " .. kosten )
        -- Kosten updaten
        Totaalkosten.updateCustomSensor(tostring(kosten))
Posted: Saturday 12 January 2019 15:49
by Knibor
Thanks for the code, it works perfect. I divide the reading though 12, so I get the month cost.
The only thing is that I have now 4 digit behind the "dot"
I tried to round the reading on 2 digit, but no succes. The script was showing no error in front of the script line, but it didn't give me an correct output.
Can't find in the manual how to do this.
Schermafbeelding 2019-01-12 om 15.48.56.png (226.29 KiB) Viewed 1210 times
Posted: Saturday 12 January 2019 18:46
by waaren
Knibor wrote: Saturday 12 January 2019 15:49 The only thing is that I have now 4 digit behind the "dot"
try this
    logging   =     {
        -- Money
        -- Device
        local Totaalkosten      = dz.devices('Totaal kosten')
        -- Kosten berekenen
        local jaarKosten       = tonumber(Gaskosten) - tonumber(StroomOpbrengst)
	local maandKosten      = dz.utils.round(jaarKosten / 12),2)
        logWrite("Kosten zijn: " .. maandKosten )
        -- Kosten updaten
        Totaalkosten.updateCustomSensor(tostring(maandKosten))
Posted: Sunday 13 January 2019 8:44
by Knibor
Thanks for the script.
I changed the line to
local maandKosten = dz.utils.round((jaarKosten / 12),2)
Yes it works!
