Chuango H4 read status (Arm,Disarmed,Home)
mf76130
Post by mf76130 »
Hi Guys,
I am brand new to the Domoticz and RFLink stuff.
I managed to solder my 433,92MHZ Arduino device and now receive a lot of my devices in the house :-)
As you can read from the header i have a Chuango H4 alarm system and i use some Doorsensors and some firedetectors. I can get the infos from the sensors and know, that i only get a ON signal, wether if its opened or closed.
What i am looking for now is, how to get the status of my alarmsystem? I would like to see if it is armed, disarmed or in home mode.
Why do i want to know it? Cause i want to only send an alert using domoticz when the system is not in disarmed mode.
Thanks for your support
michael
jurgend
Re: Chuango H4 read status (Arm,Disarmed,Home)
Post by jurgend »
mf76130 wrote: Wednesday 09 January 2019 5:18 Hi Guys,
michael
Hi, I have the eTiger (they are the same as Chuango and Eminent) did you get this working yet?
dheuts
Post by dheuts »
I have a Chuango G5 alarm system. It's the same as Etiger, Eminent EM8610, Konig SAS-ALARM300 etc.
Also 433MHz and with RFXCom, I am able to get the status of the alarm base. It will show disarmed/armed/armed home.
I use this script to switch the built-in DOmoticz alarm statuses:
 if (devicechanged['Gang Meterkast Alarmcentrale'] == 'Arm Away') then
    print('AlarmPanel Arm Away')
    commandArray['Domoticz Bedienpaneel Alarm']='Arm Away'
 if (devicechanged['Gang Meterkast Alarmcentrale'] == 'Disarm') then
    print('AlarmPanel Disarming')
    commandArray['Domoticz Bedienpaneel Alarm']='Disarm'
 if (devicechanged['Gang Meterkast Alarmcentrale'] == 'Arm Home') then
    print('AlarmPanel Arm Home')
    commandArray['Domoticz Bedienpaneel Alarm']='Arm Home'
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
