Gas Meter
Posted: Tuesday 08 January 2019 10:59
by RueDesButtes
I have tried to connect a door sensor (reed contact) to my Gas counter,
I worked few days, the cell is empty now, it has sent 1200 hits in 3 days,
the door sensor I used :
https://www.aliexpress.com/item/6pcs-lo ... 26744.html
I have also printed a sensor holder:
https://www.thingiverse.com/thing:2749173
Now I am looking to build a cheap and more time efficient solution:
- the gas counter is outdoor
- I can put a wire between the gas counter et the house
I have looked at
https://blog.danman.eu/smart-energy-meter/,
the writer explain how to build a low consumption system: is it possible to inject in domoticz data from the past?
I am open to any idea!
Re: Gas Meter
Posted: Tuesday 08 January 2019 13:26
by waaren
RueDesButtes wrote: Tuesday 08 January 2019 10:59
Yes, if you mean data from last week / last year. Look
at this topc
in summary:
- create new device with same type / subtype
- click transfer // depending on your theme, the button can be called transfer, copy or replace
- select your source (old) device. // If no source devices then the new device is not same type / subtype
Re: Gas Meter
Posted: Tuesday 08 January 2019 18:04
by RueDesButtes
waaren wrote: Tuesday 08 January 2019 13:26
at this topc
in summary:
Not exactly, what I mean is: if I use the Bluetooth solution (
https://blog.danman.eu/smart-energy-meter/), I will connect to it on a weekly basis, I would like to update the data of the existing device (I dont expect to create a new device each time)
Re: Gas Meter
Posted: Tuesday 08 January 2019 18:35
by waaren
RueDesButtes wrote: Tuesday 08 January 2019 18:04
You can inject the data in the domoticz history tables. I don't see a date/time stamp in the data. How would the formatted data look like ?
Re: Gas Meter
Posted: Wednesday 09 January 2019 17:57
by RueDesButtes
waaren wrote: Tuesday 08 January 2019 18:35
I don't know yet, as long as it is possible to inject historical data, it is fine, I will try.
