I can put a wire between the gas counter et the house
I have looked at https://blog.danman.eu/smart-energy-meter/,
the writer explain how to build a low consumption system: is it possible to inject in domoticz data from the past?
I am open to any idea!
RueDesButtes wrote: Tuesday 08 January 2019 10:59
Yes, if you mean data from last week / last year. Look at this topc
in summary:
create new device with same type / subtype
goto new device
click edit device
click transfer // depending on your theme, the button can be called transfer, copy or replace
select your source (old) device. // If no source devices then the new device is not same type / subtype
click OK
Not exactly, what I mean is: if I use the Bluetooth solution (https://blog.danman.eu/smart-energy-meter/), I will connect to it on a weekly basis, I would like to update the data of the existing device (I dont expect to create a new device each time)
RueDesButtes wrote: Tuesday 08 January 2019 18:04
You can inject the data in the domoticz history tables. I don't see a date/time stamp in the data. How would the formatted data look like ?
I don't know yet, as long as it is possible to inject historical data, it is fine, I will try.
