Thermostat Mode doesn't work anylonger?  [SOLVED]
sailmich
Post by sailmich »
I have had a dzvents code running to switch my thermostats when a significant drop of temperature happening. All is running well since one or two updates of domoticz version ago. Today I recognized that the thermostat mode was always Heat even when window is open. To check if something wrong with my thermostats I used a dummy switch 'Test'
devices = {
'Test'
if domoticz.devices('Test')=='On' then
domoticz.devices('Thermostat Mode').updateMode('Heat')
elseif domoticz.devices('Test')=='Off' then
domoticz.devices('Thermostat Mode').updateMode('Off')
In my domoticz log I got
2019-01-07 18:42:41.611 Status: dzVents: Info: Handling events for: "Test", value: "On"
2019-01-07 18:42:41.612 Status: dzVents: Info: ------ Start internal script: TestHeizungSchalten: Device: "Test (Dummys)", Index: 324
2019-01-07 18:42:41.612 Status: dzVents: Info: ------ Finished TestHeizungSchalten
Am I doing something wrong or is there a problem with dzvents?
In domoticz utilities I can change the thermostat mode and the mode is really changing on the thermostat!
Thx for any hint
Re: Thermostat Mode doesn't work anylonger?
sailmich wrote: Monday 07 January 2019 18:47 Today I recognized that the thermostat mode was always Heat even when window is open. To check if something wrong with my thermostats I used a dummy switch 'Test'
Can you execute this script ? This might give some extra information.
        on = { devices = { 'Test' }},
    local thermostat  = domoticz.devices('Thermostat Mode')
    local modes       = thermostat.modes
    local mode        = thermostat.mode
    local modeString  = thermostat.modeString
    local allModes = "\n\n"
    for i,v in ipairs(modes)  do
        allModes = allModes .. i .. " " .. v .. "\n"
    domoticz.log("Thermostat mode string:    " .. modeString,domoticz.LOG_FORCE)
    domoticz.log("Thermostat mode number:    " .. mode,domoticz.LOG_FORCE)
    domoticz.log("Thermostat possible modes: " .. allModes,domoticz.LOG_FORCE)
sailmich
Post by sailmich »
This it what I got in domoticz log.
Script #1 is copy and paste your code.
2019-01-07 20:06:01.865 Status: dzVents: Debug: Event triggers:
2019-01-07 20:06:01.865 Status: dzVents: Debug: - Device: Test
2019-01-07 20:06:01.664 Error: EventSystem: Lua script Script #1 did not return a commandArray
2019-01-07 20:06:02.047 Error: EventSystem: Lua script Script #1 did not return a commandArray
sailmich wrote: Monday 07 January 2019 20:09 This it what I got in domoticz log.
It looks like you saved it as a Lua script. You should save it as a dzVents script.
sailmich
Post by sailmich »
:o I didn't realized that. :oops:
2019-01-07 21:45:02.059 Status: User: Admin initiated a switch command (324/Test/On)
2019-01-07 21:45:02.164 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2019-01-07 21:45:02.298 Status: dzVents: Debug: Processing device-adapter for Test: Switch device adapter
2019-01-07 21:45:02.299 Status: dzVents: Debug: dzVents version: 2.4.9
2019-01-07 21:45:02.299 Status: dzVents: Debug: Event triggers:
2019-01-07 21:45:02.299 Status: dzVents: Debug: - Device: Test
2019-01-07 21:45:02.340 Status: dzVents: Info: Handling events for: "Test", value: "On"
2019-01-07 21:45:02.340 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "Test (Dummys)", Index: 324
2019-01-07 21:45:02.344 Status: dzVents: Debug: Processing device-adapter for Thermostat Mode: Z-Wave Thermostat mode device adapter
2019-01-07 21:45:02.344 Status: dzVents: !Info: Thermostat mode string: Heat
2019-01-07 21:45:02.344 Status: dzVents: !Info: Thermostat mode number: 1
2019-01-07 21:45:02.344 Status: dzVents: !Info: Thermostat possible modes:
2019-01-07 21:45:02.344 1 Off
2019-01-07 21:45:02.344 2 Heat
2019-01-07 21:45:02.344 3 Heat Eco
2019-01-07 21:45:02.344 4 Full Power
2019-01-07 21:45:02.344 5 Manufacturer Specific
2019-01-07 21:45:02.344 Status: dzVents: Info: ------ Finished Script #1
I might have make a mistake during copy and paste and saved as at lua instead of dzvents. Now I saved my script new as dzvents and I can find it under dzVents/generated_scripts so should work again.
Thank to spent your time! Next time I will check it before post as a problem.
sailmich wrote: Monday 07 January 2019 22:06 Now I saved my script new as dzvents and I can find it under dzVents/generated_scripts so should work again.
Leaving the question why the Thermostat is not updated. We see that Off is one of the possible modes. But it does not seem to work ?
I had a look at the device-adapter in dzVents and do see something strange but do not know for sure if it is a bug. i don't own this device so hopefully you can test (if the problem is still there )?
Can you change in file
domoticz\dzVents\runtime\device-adapters\zwave_thermostat_mode_device.lua
line 45 from
 					return device.update(i, i)
to
					return device.update(i, mode)
and test again ?
It might help you and others and if not, we at least tried and tested and can be reverted without any problem.
sailmich
Post by sailmich »
I can't see any different in log.
2019-01-08 04:44:14.244 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "Test (Dummys)", Index: 324
2019-01-08 04:44:14.248 Status: dzVents: Debug: Processing device-adapter for Thermostat Mode: Z-Wave Thermostat mode device adapter
2019-01-08 04:44:14.248 Status: dzVents: !Info: Thermostat mode string: Heat
2019-01-08 04:44:14.248 Status: dzVents: !Info: Thermostat mode number: 1
2019-01-08 04:44:14.248 Status: dzVents: !Info: Thermostat possible modes:
2019-01-08 04:44:14.248 1 Off
2019-01-08 04:44:14.248 2 Heat
2019-01-08 04:44:14.248 3 Heat Eco
2019-01-08 04:44:14.248 4 Full Power
2019-01-08 04:44:14.248 5 Manufacturer Specific
2019-01-08 04:44:14.249 Status: dzVents: Info: ------ Finished Script #1
sailmich
Post by sailmich »
My window open script doesen't work this morning.
      timer = {'every 5 minutes'}[attachment=0]Bildschirmfoto vom 2019-01-08 06-14-39.png[/attachment]
   data = {
      previousTemperature1 = { initial = 100 }
   execute = function(domoticz)
      local schlafzimmerSensor = domoticz.devices('Schlafzimmer')
        --Schlafzimmer
      if (domoticz.data.previousTemperature1 - schlafzimmerSensor.temperature) >= 0.3 and domoticz.devices('Thermostat Mode Schlafzimmer').state == Heat then
         -- Window is open there was a significant drop
        domoticz.devices('Thermostat Mode Schlafzimmer').updateMode('Off')
        domoticz.devices('Lüften').switchOn() -- Use as a log
    elseif (domoticz.data.previousTemperature1 - schlafzimmerSensor.temperature) < 0.2 and domoticz.devices('Thermostat Mode Schlafzimmer').state == Off then
        domoticz.devices('Lüften').switchOff()
         -- Window is closed
        domoticz.devices('Thermostat Mode Schlafzimmer').updateMode('Heat')
      -- store current value for next cycle
      domoticz.data.previousTemperature1 = schlafzimmerSensor.temperature
Between 5:55 and 6:00 temperature droped 0.4°C so should set thermostat to Off. But doesn't.
Bildschirmfoto vom 2019-01-08 06-14-39.png (17.61 KiB) Viewed 30764 times
sailmich wrote: Tuesday 08 January 2019 4:50 I can't see any different in log.
No the proposed change is for the actual update. My script only displays the status and the options.
So please test with my proposed change and see if the update (your script) works.
sailmich
Post by sailmich »
No it doesn't work.
sailmich wrote: Tuesday 08 January 2019 11:10 No it doesn't work.
Shouldn't there be quotes around Heat and Off ? Please try script below with both versions of the device-adapter. Thx
            on      =   { timer                 = {'every 5 minutes'}},
            data    =   { previousTemperature1  = { initial = 100   }},
        --Schlafzimmer
        if (domoticz.data.previousTemperature1 - schlafzimmerSensor.temperature) >= 0.3 and domoticz.devices('Thermostat Mode Schlafzimmer').state == 'Heat' then
        elseif (domoticz.data.previousTemperature1 - schlafzimmerSensor.temperature) < 0.2 and domoticz.devices('Thermostat Mode Schlafzimmer').state == 'Off' then
            -- Window is closed
sailmich
Post by sailmich »
Of course you are right quotes are necessary, happened because of all my tries :( . But also with quotes it doesn't work.
To test I use a dummy switch as a trigger.This work
      devices = {'Lüften'}
      if domoticz.devices('Lüften').state == 'On' then
     elseif domoticz.devices('Lüften').state == 'Off' then
This doesn't work
      if domoticz.devices('Lüften').state == 'On' and domoticz.devices('Thermostat Mode Schlafzimmer').state == 'Heat' then
     elseif domoticz.devices('Lüften').state == 'Off' and domoticz.devices('Thermostat Mode Schlafzimmer').state == 'Off' then
So something wrong with second part of if statement.
sailmich wrote: Tuesday 08 January 2019 14:23 So something wrong with second part of if statement.
Is your first script succesfull with the modified domoticz\dzVents\runtime\device-adapters\zwave_thermostat_mode_device.lua or with the original ?
I guess you should change the attribute "state" to "modeString" in the 2nd script for the Thermostate device like
      if domoticz.devices('Lüften').state == 'On' and domoticz.devices('Thermostat Mode Schlafzimmer').modeString == 'Heat' then
     elseif domoticz.devices('Lüften').state == 'Off' and domoticz.devices('Thermostat Mode Schlafzimmer').modeString == 'Off' then
sailmich
Post by sailmich »
waaren wrote: Tuesday 08 January 2019 17:24 Is your first script succesfull with the modified domoticz\dzVents\runtime\device-adapters\zwave_thermostat_mode_device.lua or with the original ?
With booth! With mode I got Heat and Off in the log, with i I got 1 and 0. Booth switch the mode from Heat to Off and vice versa.
waaren wrote: Tuesday 08 January 2019 17:24 I guess you should change the attribute "state" to "modeString" in the 2nd script for the Thermostate device like
You are my hero! That did the trick. I didn't try that. Examples in documentation of dzVents would be fine for idiots like me :lol:
sailmich wrote: Tuesday 08 January 2019 18:57 Examples in documentation of dzVents would be fine for idiots like me :lol:
Not with an example but it's definitely in the wiki :)
sailmich
Re: Thermostat Mode doesn't work anylonger?  [SOLVED]
Post by sailmich »
I also saw it but I'm not clever enough to anticipate and use it.
Thanks again I learned a lot!
zanna1972
Post by zanna1972 »
Hi, do you know how to change the thermostat mode using json api?
zanna1972 wrote: Monday 08 March 2021 21:39 Hi, do you know how to change the thermostat mode using json api?
There are different types of thermostats What is the type and subtype of the thermostat as seen on the devices tab?
zanna1972
Post by zanna1972 »
Type=General
Subtype=thermostat mode
zanna1972 wrote: Monday 08 March 2021 21:48 Type=General
Can you run below script to identify the details of this device?
It might help to find the right API call for it.
return
    on =
        timer =
            'at 17:32', -- change to the time you want to dump the attributes of the device
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'dumpAttributes',
    execute = function(dz)
        local myDevice = dz.devices(1656)         -- your device idx
        -- if you don't have sqlite3 yet on your system install it with sudo apt install sqlite3
        local sqlite = '/usr/local/bin/sqlite3'  -- find your sqlite3 location with "which sqlite3" and change here accordingl
        local function dumpAttributes(dv)
            dz.log(dv.idx .. ': ' .. dv.name .. ': attribute       -> value',dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ':                                    -- dzVents',dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': type, subType   -> ' .. dv.deviceType .. ', '.. tostring(dv.deviceSubType),dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': switchTypeValue -> ' .. dv.switchTypeValue ,dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': adapters        -> ' .. dz.utils._.str(dv._adapters),dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': rawData         -> ' .. dz.utils._.str(dv.rawData),dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': hwType          -> ' .. dv.hardwareType .. ', ' .. dv.hardwareTypeValue,dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': levelNames      -> ' .. dz.utils._.str(dv.levelNames),dz.LOG_FORCE)
            dz.log(dv.idx .. ': ' .. dv.name .. ': modes           -> ' .. dz.utils._.str(dv.modes),dz.LOG_FORCE)
        local function dumpDeviceStatus(dv)
            local sqlResult, result = dz.utils.osCommand('sudo ' .. sqlite .. ' ' .. '-header domoticz.db "select * from deviceStatus where id = ' .. dv.idx .. '"')
            if result ~= 0 then
                dz.log('Result: ' .. result, dz.LOG_ERROR)
                sqlResult = dz.utils.stringSplit(sqlResult,'\n')
                local header = dz.utils.stringSplit(sqlResult[1],'|')
                local values = dz.utils.stringSplit(sqlResult[2],'|')
                dz.log(dv.idx .. ': ' .. dv.name .. ': field           -> value',dz.LOG_FORCE)
                dz.log(dv.idx .. ': ' .. dv.name .. ':                                    -- database',dz.LOG_FORCE)
                for index, attribute in ipairs(header) do
                    dz.log(dv.idx .. ': ' .. dv.name .. ': ' .. dz.utils.rightPad(( attribute or '') ,15) .. ' -> ' .. ( values[index] or 'nil') ,dz.LOG_FORCE)
        dumpAttributes(myDevice)
            dz.log('',dz.LOG_FORCE)
        dumpDeviceStatus(myDevice)
