Domoticz does not recognize old ELV sensors (WS2500/WS7000)
WS2500
Post by WS2500 »
Hi All,
I'm new to this board, installed Domoticz on Raspbian to read data from my new Weather Station (TFA Nexus) using a RFXtrx433E.
Everything works fine for this station so far (but I'm still learning of course).
My old station was a ELV WS2500 (should be equal to LaCrosse WS2500 with WS7000x sensors sending at 433,92 MHz).
I was hoping to get some data from the old sensors as well - at least I expected to see them as "undecoded" if I switch on "undec on".
If I use the windows application RFXManager I get tons of data as soon as I put batteries into on of the sensors, output looks like this:
RFXtrx433    COM4  Serialnr: XXXXXX
04.01.2019 08:29:34:166= Reset receiver/transceiver
04.01.2019 08:29:58:683= Get Status
04.01.2019 08:29:58:761
Packettype        = Interface Message
subtype           = Interface Response
Sequence nbr      = 4
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 1033
Firmware Type     = Pro1
Noise level       = 124
Transmit power    = 10dBm
Hardware version  = 1.3  RFXtrx433E
Undec             on
Imagintronix      enabled
Byron SX          enabled
RSL               enabled
Lighting4         enabled
FineOffset        enabled
Rubicson          enabled
AE Blyss          enabled
BlindsT1-4        enabled
BlindsT0          enabled
Legrand           enabled
La Crosse         enabled
Hideki            enabled
AD LightwaveRF    enabled
Mertik            enabled
Visonic           enabled
ATI,Cartelectroni enabled
Oregon Scientific enabled
Meiantech         enabled
HomeEasy EU       enabled
AC                enabled
ARC               enabled
X10               enabled
FunkBus           disabled
MCZ               disabled
HomeConfort       enabled
KeeLoq            enabled
04.01.2019 08:31:48:285
RAW Packet:
F87F00000102FD01C2030301C5030201C5030101C4030301C6030001C4030301C4030201C1030501C3030301C5011803A8011E03AE030301C5030201C5030101C6011603AE011803AB011C03AB030401C5030101BA0127039D0129039B030F01BC030D01BB012103A1012303A10128039C031601B4012203A1031101B9012003AD011903AC030401C602FF01C5030201C5011603AE011903AA030601C5030101C6030201C4011803AC030301C7030001C4030101C5030301C4011903AC030301C5011803AC011A03AA030401C5011803AB030401C5030301C2030301C5011703AB011A03AA011D03A8011E03AA011D03AB030401C401170000
Packettype    = RAW Packet
Packet Length = 248
subtype       = RAW packet
Sequence nbr  = 0
Repeat        = 1
Nbr of pulses = 61
765  450  771  453  770  453  769  452  771  454  768  452  771  452  770  449  773  451  771  453  280  936  286  942  771  453  770  453  769  454  278  942  280  939  284  939  772  453  769  442  295  925  297  923  783  444  781  443  289  929  291  929  296  924  790  436  290  929  785  441  288  941  281  940  772  454  767  453  770  453  278  942  281  938  774  453  769  454  770  452  280  940  771  455  768  452  769  453  771  452  281  940  771  453  280  940  282  938  772  453  280  939  772  453  771  450  771  453  279  939  282  938  285  936  286  938  285  939  772  452  279  0
04.01.2019 08:31:51:348
RAW Packet:
F87F000101030801C4030201C3030401C3030501C0030401C4030301C1030301C3030301C5030101C4030301C5011603AE011903AB030901C1030101C5030201C2011903AA011C03AC011B03A8030801C5030201C2011903AC011A03AC030401C5030501C3011703A8011E03AA011C03AA030501C6011503AC030601C3011A03AA011A03AC030401C5030201C3030301C5011903A8030801C3030301C1030501C5030201C2011A03AB011A03AA030501C4030301C5030001C2011B03AD030301C4011903AA011C03AB030501C5011903AB030501C3030201C0030801BD012003AC011A03AA011C03AA011A03AD011903AD030301C501190000
Packet Length = 248
Sequence nbr  = 1
Repeat        = 1
Nbr of pulses = 61
776  452  770  451  772  451  773  448  772  452  771  449  771  451  771  453  769  452  771  453  278  942  281  939  777  449  769  453  770  450  281  938  284  940  283  936  776  453  770  450  281  940  282  940  772  453  773  451  279  936  286  938  284  938  773  454  277  940  774  451  282  938  282  940  772  453  770  451  771  453  281  936  776  451  771  449  773  453  770  450  282  939  282  938  773  452  771  453  768  450  283  941  771  452  281  938  284  939  773  453  281  939  773  451  770  448  776  445  288  940  282  938  284  938  282  941  281  941  771  453  281  0
04.01.2019 08:31:54:301
RAW Packet:
F87F000201030D01C4030201C5030101C4030201C5030301C5030201C2030801B5031101BB030801C5030301BB012103A1012303A6030C01BC030C01C0030301BE012003A5011C03A9012103A7030801C1030801B40126039F0129039C031401B5030F01C4011703AD011A03AA011C03AC030401C3011903AB030401C5011803AA011C03AC030401C5030301C2030401BE011E03A9011C03A8030801C3030601B70127039D0127039F012703A1031001B9030B01BA030A01C5011703AB030601C5011603AD011903AC030501C2011A03AB011B03AB030401C5030301C3030301C1011903AC011D03A8030601C4030301C3011A03A8011E0000
Packet Length = 248
Sequence nbr  = 2
Repeat        = 1
Nbr of pulses = 61
781  452  770  453  769  452  770  453  771  453  770  450  776  437  785  443  776  453  771  443  289  929  291  934  780  444  780  448  771  446  288  933  284  937  289  935  776  449  776  436  294  927  297  924  788  437  783  452  279  941  282  938  284  940  772  451  281  939  772  453  280  938  284  940  772  453  771  450  772  446  286  937  284  936  776  451  774  439  295  925  295  927  295  929  784  441  779  442  778  453  279  939  774  453  278  941  281  940  773  450  282  939  283  939  772  453  771  451  771  449  281  940  285  936  774  452  771  451  282  936  286  0
04.01.2019 08:31:57:363
RAW Packet:
F87F000301030D01C6030201C5030301C2030201C3030301C4030601C0030301C4030301C3030301C1030401C5011803AD011903AC030801B7031001B7030F01B8012403A8011B03A9011B03AC030501C5030201C6011603AD030401C4030401C1030301C2030401C3011A03A8030501C5011803AE011903AB030501C5011703AA011D03AB030301C6030101C5030301C2011903AC011B03A9011B03AB030601C3030401C6011703AB030401C5011803AB030401C5030001C2011F03A7030601C4011903AD011903AA030601C3011903AB030601C5011703AE030301C3030301C4011903AA011D03A8030601C5011903AC011903AA011C0000
Packet Length = 248
Sequence nbr  = 3
Repeat        = 1
Nbr of pulses = 61
781  454  770  453  771  450  770  451  771  452  774  448  771  452  771  451  771  449  772  453  280  941  281  940  776  439  784  439  783  440  292  936  283  937  283  940  773  453  770  454  278  941  772  452  772  449  771  450  772  451  282  936  773  453  280  942  281  939  773  453  279  938  285  939  771  454  769  453  771  450  281  940  283  937  283  939  774  451  772  454  279  939  772  453  280  939  772  453  768  450  287  935  774  452  281  941  281  938  774  451  281  939  774  453  279  942  771  451  771  452  281  938  285  936  774  453  281  940  281  938  284  0
04.01.2019 08:32:00:317
RAW Packet:
F87F00040102FC01C2030301C6030101C4030201C3030301C3030301C5030201C2030301C5030301C5030001C7011703AB011B03AB030401C5030001C2030401C4011903AC011E03A9011903AC030501C2030401C5011A039F031001C3030101C3030401C4030201C2011A03AB030401C4011903AB011A03AC030501C5011703AE011903A8030701C5030101C3030401C4011803AA011C03AC011903AC011A03AB030601C4011803AC030801C1011803A8030801C5030101C3011903AB030601C5011803AB011A03AD030301C4011903AA030A01BF011903AB011E03A7030601C3011A03AB011B03AA030601C4011903A9030601C501170000
Packet Length = 248
Sequence nbr  = 4
Repeat        = 1
Nbr of pulses = 61
764  450  771  454  769  452  770  451  771  451  771  453  770  450  771  453  771  453  768  455  279  939  283  939  772  453  768  450  772  452  281  940  286  937  281  940  773  450  772  453  282  927  784  451  769  451  772  452  770  450  282  939  772  452  281  939  282  940  773  453  279  942  281  936  775  453  769  451  772  452  280  938  284  940  281  940  282  939  774  452  280  940  776  449  280  936  776  453  769  451  281  939  774  453  280  939  282  941  771  452  281  938  778  447  281  939  286  935  774  451  282  939  283  938  774  452  281  937  774  453  279  0
04.01.2019 08:32:03:380
RAW Packet:
F87F000501030001C5030401C2030101C4030301C4030301C3030301C4030301C5030001C6030001C602FF01C8011403AF011703AE030301C5030201C3030201C2011B03AE011903AA011C03AB030401C5030101C5011703AF030201C6030001C702FF01C5030301C6011503AC030401C5011703AF011803AF030301C5011603AD011803AF030301C0030501C802FF01C4011903AD011B03A9030301C6030301C3030101C4011803AE011903A9011D03AE030301C3030301C5011903AB030401C5011603AE011903AC030801C3011703AA011B03AD030401BF030601C3030401C1011C03A5012003AD011903AD030301C6011703AB011B0000
Packet Length = 248
Sequence nbr  = 5
Repeat        = 1
Nbr of pulses = 61
768  453  772  450  769  452  771  452  771  451  771  452  771  453  768  454  768  454  767  456  276  943  279  942  771  453  770  451  770  450  283  942  281  938  284  939  772  453  769  453  279  943  770  454  768  455  767  453  771  454  277  940  772  453  279  943  280  943  771  453  278  941  280  943  771  448  773  456  767  452  281  941  283  937  771  454  771  451  769  452  280  942  281  937  285  942  771  451  771  453  281  939  772  453  278  942  281  940  776  451  279  938  283  941  772  447  774  451  772  449  284  933  288  941  281  941  771  454  279  939  283  0
Is there any way to get this data decoded and shown in Domoticz?
Wishing all of you a Happy New Year and Hoping for some hints,
WS2500
b_weijenberg
Re: Domoticz does not recognize old ELV sensors (WS2500/WS7000)
Post by b_weijenberg »
undec mode cannot be used in Domoticz. See also chapter 2.3 in the RFXtrx User Guide.
WS2500 is not in the list of supported devices: see chapter 2.2.2.
contact support rfxcom.com for more information
RFX-433, RFX-433EMC, RFX-868
WS2500
Post by WS2500 »
Thanks for the quick reply. That's no good news, so I need to get some new sensors.
WS2500
