I noticed that an change of text sensor (in my case with a lua script event) is not published on domoticz/out.
Is there anything in my settings that I overlooked?
My work around for this is to have an extra switch sensor that changes state together with the change of the text sensor and use node red to trigger a 'getdeviceinfo' command but have a 2 seconds delay with this work around.
MQTT issue? Change of text sensor not published
- waaren
Re: MQTT issue? Change of text sensor not published
text sensors are not publishedwimd1908 wrote: Thursday 03 January 2019 22:25 I noticed that an change of text sensor (in my case with a lua script event) is not published on domoticz/out.
Much quicker would be to send a /json.htm?type=command¶m=udevice&idx=<ix of custom sensor>&nvalue=0&svalue=YourText from a script or use os.execute with the mosquitto_pub command.My work around for this is to have an extra switch sensor that changes state together with the change of the text sensor and use node red to trigger a 'getdeviceinfo' command but have a 2 seconds delay with this work around.
wimd1908
- Domoticz version: 4.9700
Thanks for the tip.
The addition switch I have is based on earlier and similar issue with MySensors.
With the os.execute command I don't have any delays yet.
