Dear Friends,
I could pack wifi_router_function+domoticz+mqtt_broker on a 20$ pocket router.
It is for low budget wifi based home-automation setup. check my blog for more details.
http://albert-david.blogspot.com/2019/0 ... -home.html
wish you happy new year!!
Domoticz on 20$ pocket router
- EdddieN
- Domoticz version: 4.9700
Re: Domoticz on 20$ pocket router
I like it very much!
I have the same router, worth a try!
11101101 - www.machinon.com
I tried to plugin ZMEEUZB usb dongle but dmesg was showing
then i tried to plugin the dongle through external powered usb hub - this time i saw the following on dmesg
Maybe i need to enable the driver for ZMEEUZB in the kernel config, will try this later some time to see if this plays well.
device descriptor read/64, error -32
attempt power cycle
new full-speed USB device number 13 using ehci-platform
