triggering an "if"
Adso76
triggering an "if"
Post by Adso76 »
In the following simple script the second "if" doesn't work.
		devices = {
			'wall button 1',
			'sleepingroom light'
	    if ((device.name == 'wall button 1' and device.changed)) then
		    if ((device.name == 'sleepingroom light' and device.state == "Off")) then
		        domoticz.log('Light will wee turned on ')
I can trigger the first if when I push the "wall button 1" (GPIO), then I want to check wether the light is on or off and this doesn't work.
Or maybe there is another way to do this?
Thanks,
Arek
Domoticz Version: 4.9895 running on Raspberry Pi B 3+ (Raspbian). PCF8574 as input and output.
ronaldbro
Re: triggering an "if"
Post by ronaldbro »
Hi Arek,
The second if is always false because in the first if you already checked if it is 'wall button 1' and if so the it's not 'sleepingroom light'.
Also no need to check if it's changed, it triggered the event so ofcource it's changed.
		devices = {
			'wall button 1',
	    if device.name == 'wall button 1' then
		    if domiticz.devices('sleepingroom light').state == "Off" then
regards Ronald
Adso76
Post by Adso76 »
@Ronald
Thanks a lot! Now it works!
However, in the first if I will stay with device.changed because in my case the wall button is not a push button (monostable) but typical physical switch (bistable).
Regardes,
Arek
