Hi.
I have purchased Fibaro Heat Controller with Domoticz. I have several questions:
1. Should Fibaro show me the temperature of his own temp sensor? (not external one)
2. I have set the temperature , but the fibaro doesn't wake up and nothing happened. Please advice how to resolve this.
3. Also I have some warning at this fibaro - how o see, what is it and to resolve it.
Thanks in advance for your answers.
Fibaro Heat Controller problem
smho
Re: Fibaro Heat Controller problem
Hi DoMoney,
I also recenty bought 5 Fibaro Heat Controller to extend my Z-Wave network. And I'm also new to this forum and have not so much experience with Domoticz. I just wrote my first DzVents....
I had the same problem in the beginning that I was not able to set temperature resp. the valves did not do what I wanted them to do.
I use this code in my DzVents script:
Here is my version of the heat controller device
result of:
I found a kind of version at the open z-wave control panel if I select the heat controller device and then the Information radio button.
It says protocol version: 4.61
application version: 4.03 - is 4.03 my current firmware version?
also I noticed some errors
And finally - is there by any chance someone in the Vienna region who owns a Fibaro Home Controller and would be willing to update my Fibaro devices to the latest firmware? (i think it's a shame that Fibaro does not provide an OTA update to all customers!)
I think the answer is "no". (not sure about the new firmware ?!)1. Should Fibaro show me the temperature of his own temp sensor? (not external one)
You have to set the correct operation mode (off/heat/manufacturer specific) - see manual page 72. I have set the temperature , but the fibaro doesn't wake up and nothing happened. Please advice how to resolve this.
- Spoiler: show
- Spoiler: show
result of:
- Spoiler: show
- Spoiler: show
http://MY-IP:MY-PORT/ozwcp/cp.htmlCode: Select all
Error, Node007, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_APPLICATION_STATUS endpoint 0Who is online
