Group switch the lights
misko903
Domoticz version: Latest
Post by misko903 »
Hi, I have created an event:
   on = { devices = { 18, 20, 25 }},                -- Spalna Tlacidla: 18-Spálňa Posteľ Tlačidlo, 20-Spálňa Von Tlačidlo, 25-Matusik
--   on = { scenes = { 'AllLights' }},
   execute = function(dz, item )
        if item.state == "Click" then
            dz.devices(49).toggleSwitch()           -- Spalna Pasik Hore
        elseif item.state == "Double Click" then
            dz.devices(33).toggleSwitch()           -- Spalna Pasik Dole
        elseif item.state == "Long Click" then
            dz.scenes('AllLights').switchOff()     -- Všetky svetlá Group
	domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
Everything works, except the Long Click - Group switching. In Scenes I have created group called AllLights - manually switching it on or off always work. but not through the button dzVents script.
What is wrong in my script?
Thank you!
Re: Group switch the lights
misko903 wrote: Thursday 20 December 2018 7:06 Hi, I have created an event:
My guess is that you created AllLights as a group. If that is the case you should use
dz.groups('AllLights').switchOff()     -- Všetky svetlá Group
If that does not solve your issue you should turn on debug logging on the script level and look at the relevant loglines.
misko903
Post by misko903 »
Thanks, partially works, but it has ended with error:
2018-12-30 15:41:41.249 Status: User: Admin initiated a switch command (18/Spálňa Posteľ Tlačidlo/Set Level)
2018-12-30 15:41:41.421 Status: dzVents: Info: Handling events for: "Spálňa Posteľ Tlačidlo", value: "Long Click"
2018-12-30 15:41:41.421 Status: dzVents: Info: ------ Start internal script: Spalna Tlacidla: Device: "Spálňa Posteľ Tlačidlo (Xiaomi Gateway)", Index: 18
2018-12-30 15:41:41.422 Status: dzVents: Error (2.4.9): An error occured when calling event handler Spalna Tlacidla
2018-12-30 15:41:41.422 Status: dzVents: Error (2.4.9): ...cz/scripts/dzVents/generated_scripts/Spalna Tlacidla.lua:14: attempt to index global 'domoticz' (a nil value)
2018-12-30 15:41:41.422 Status: dzVents: Info: ------ Finished Spalna Tlacidla
2018-12-30 15:41:41.516 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-30 15:41:42.035 (Xiaomi Gateway) Color Switch (Gateway Svetlo)
2018-12-30 15:41:42.090 Activating Scene/Group Device: Vianočné Zásuvka (Off)
2018-12-30 15:41:42.250 (Xiaomi Gateway) Light/Switch (Vianočné Zásuvka)
2018-12-30 15:41:42.302 Activating Scene/Group Device: Obývačka Polička (Off)
2018-12-30 15:41:42.362 (Yeelight Controller) Color Switch (Obývačka Polička)
2018-12-30 15:41:42.420 Activating Scene/Group Device: Obývačka Stena 1 (Off)
2018-12-30 15:41:44.869 (Xiaomi Gateway) General/kWh (Pivnica Zasuvka Spotreba)
2018-12-30 15:41:45.569 Activating Scene/Group Device: Obývačka Stena 2 (Off)
2018-12-30 15:41:45.519 Error: YeeLight: Exception: connect: No route to host
2018-12-30 15:41:48.770 Activating Scene/Group Device: Pivnica Zásuvka (Off)
2018-12-30 15:41:48.934 (Xiaomi Gateway) Light/Switch (Pivnica Zásuvka)
2018-12-30 15:41:48.986 Activating Scene/Group Device: Spálňa Pásik Dole (Off)
2018-12-30 15:41:48.719 Error: YeeLight: Exception: connect: No route to host
2018-12-30 15:41:49.055 (Yeelight Controller) Color Switch (Spálňa Pásik Dole)
2018-12-30 15:41:49.107 Activating Scene/Group Device: Spálňa Pasik Hore (Off)
2018-12-30 15:41:49.171 (Yeelight Controller) Color Switch (Spálňa Pasik Hore)
2018-12-30 15:41:49.223 Activating Scene/Group Device: Technická Stena (Off)
2018-12-30 15:41:49.284 (Yeelight Controller) Color Switch (Technická Stena)
I pressed the button in domoticz, not the HW button.
Error on line 14 is probably something with logging/debugging?
The Exception Errors - no route to host seems to be lights which have no power.
misko903 wrote: Sunday 30 December 2018 15:49 Thanks, partially works, but it has ended with error:
You hand over "dz" to the function in line 6 but refer to "domoticz" in line 14.
Change both "domoticz" to "dz" in line 14 to get rid of this error.
misko903
Post by misko903 »
thanks again waaren,
I have also --ed the logging line
