Domoticz started segfaulting
JoshDinsdale
Post by JoshDinsdale »
Hi Guys
My Domoticz setup on Raspberry pi has started segfaulting all of a sudden. The only things i had been messing with was my dashticz configuration which runs on a seperate nginx instance so should be unrelated.
Anyway last time this happened i did ./updatebeta which fixed it, tried this time and hasnt fixed. Tried ./updaterelease which doesnt work as my DB version is incompatible.
I've also tried updating the os using apt dist-upgtrade which hasnt made a difference either.
Manual startup looks like this:
root@domoticz:/home/pi/domoticz# ./domoticz
2018-12-18 18:25:26.743 Status: Domoticz V4.10298 (c)2012-2018 GizMoCuz
2018-12-18 18:25:26.744 Status: Build Hash: 67682dfd, Date: 2018-12-18 07:41:21
2018-12-18 18:25:26.744 Status: Startup Path: /home/pi/domoticz/
2018-12-18 18:25:26.804 Sunrise: 08:03:00 SunSet: 16:01:00
2018-12-18 18:25:26.804 Day length: 07:59:00 Sun at south: 12:05:00
2018-12-18 18:25:26.805 Civil twilight start: 07:23:00 Civil twilight end: 16:40:00
2018-12-18 18:25:26.805 Nautical twilight start: 06:41:00 Nautical twilight end: 17:22:00
2018-12-18 18:25:26.805 Astronomical twilight start: 06:01:00 Astronomical twilight end: 18:02:00
2018-12-18 18:25:26.806 Status: EventSystem: reset all events...
2018-12-18 18:25:26.955 Status: PluginSystem: Started, Python version '3.4.2'.
2018-12-18 18:25:26.958 Status: Philips Hue: Using default poll interval of 10 secs.
2018-12-18 18:25:26.982 Active notification Subsystems: email, gcm, pushover (3/13)
2018-12-18 18:25:26.985 Status: WebServer(HTTP) started on address: :: with port 8080
2018-12-18 18:25:26.998 Status: WebServer(SSL) started on address: :: with port 443
2018-12-18 18:25:27.004 Status: Proxymanager started.
2018-12-18 18:25:27.006 Starting shared server on: :::6144
2018-12-18 18:25:27.007 Status: TCPServer: shared server started...
2018-12-18 18:25:27.009 Status: RxQueue: queue worker started...
2018-12-18 18:25:27.830 Status: setcolbrightnessvalue: ID: 1f1, bri: 62, color: '{m: 3, RGB: ff0005, CWWW: 0000, CT: 0}'
2018-12-18 18:25:27.843 (MQTT Devices) Color Switch (Test Strip)
2018-12-18 18:25:27.845 Status: Incoming connection from: 127.0.0.1
2018-12-18 18:25:29.013 Status: MySensors: Worker started...
2018-12-18 18:25:29.017 Status: Hardware Monitor: Started
2018-12-18 18:25:29.041 Status: RFXCOM: Worker started...
2018-12-18 18:25:29.042 Status: Pinger: Worker started...
2018-12-18 18:25:29.043 Status: Philips Hue: Worker started...
2018-12-18 18:25:29.044 Status: Wunderground: Worker started...
2018-12-18 18:25:29.045 Status: Nest: Worker started...
2018-12-18 18:25:29.047 Status: XiaomiGateway (ID=26): Delaying worker startup...
2018-12-18 18:25:30.017 Status: MySensors: Using serial port: /dev/ttyACM0
2018-12-18 18:25:30.045 Status: MQTT: Connecting to localhost:1883
2018-12-18 18:25:30.047 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2018-12-18 18:25:30.151 Status: MQTT: connected to: localhost:1883
2018-12-18 18:25:30.252 Status: MQTT: Subscribed
2018-12-18 18:25:30.351 (Hue Bridge) Light/Switch (Server Cupboard Light)
2018-12-18 18:25:30.352 MQTT: Topic: domoticz/in, Message: {"command": "switchlight", "idx": 490, "switchcmd": "On" }
2018-12-18 18:25:30.367 (Hue Bridge) Light/Switch (Landing Light)
2018-12-18 18:25:30.379 (Hue Bridge) Light/Switch (Girls Room Light)
2018-12-18 18:25:30.391 (Hue Bridge) Light/Switch (Vincents Room Light)
2018-12-18 18:25:30.402 (Hue Bridge) Light/Switch (Under Stairs Cupboard Light)
2018-12-18 18:25:30.416 (Hue Bridge) Light/Switch (Hallway)
2018-12-18 18:25:30.429 (Hue Bridge) Light/Switch (Living room 1)
2018-12-18 18:25:30.439 (Hue Bridge) Light/Switch (Group Girls Room)
2018-12-18 18:25:30.448 (Hue Bridge) Light/Switch (Group Vincent's Room)
2018-12-18 18:25:30.458 (Hue Bridge) Light/Switch (Group Landing)
2018-12-18 18:25:30.469 (ML_GW-01) Color Switch (Habitat 2)
2018-12-18 18:25:30.476 (Hue Bridge) Light/Switch (Group Server Cupboard)
2018-12-18 18:25:30.485 (Hue Bridge) Light/Switch (Group Under Stairs Cupboard)
2018-12-18 18:25:30.493 (Hue Bridge) Light/Switch (Group Living Room)
2018-12-18 18:25:30.502 (Hue Bridge) Light/Switch (Group Hallway)
Segmentation fault
Any ideas, I'm clutching at straws here?
JoshDinsdale
Re: Domoticz started segfaulting
Weird, restored a backup from earlier in the day and its running, however complaining about the philips hue worker... will update progress soon.
