https request in LUA for DarkSky forecast Topic is solved
Kifo
Post by Kifo »
As Weather Underground will stop its free service soon I am trying to adapt my lua scripts to use forecast data from DarkSky.
The DarkSky API works only with https requests. Thus I only get the reply "Bad Request" instead of the JSON reply if I use the following code to access the DarkSky forecast.
    io = require('io')
    http = require('socket.http')
    json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
    reply = http.request("https://api.darksky.net/forecast/[APIcode]/[lat],[lon]?units=si")
    print(reply)
Of course I replaced the [] section with my own data.
How can I make a https request in lua (I am still using Domoticz V3.5877 for other compatibility reasons)?
alanlsmith
Domoticz version: Latest β
Re: https request in LUA for DarkSky forecast
Post by alanlsmith »
if it helps this is the code snippet that collects the data from the script I use:
function os_capture(cmd, raw)
    local f = assert(io.popen(cmd, 'r'))
    local s = assert(f:read('*a'))
    f:close()
    if raw then return s end
    s = string.gsub(s, '^%s+', '')
    s = string.gsub(s, '%s+$', '')
    s = string.gsub(s, '[\n\r]+', ' ')
    return s
local api_key="mykey" -- darksky secret key
local coord="lat, long"                 -- latitude,longitude
-- Querying Darksky --
json = (loadfile "/home/alan/domoticz/scripts/lua/JSON.lua")()  -- For Linux
result=os_capture('curl -s "https://api.darksky.net/forecast/'..api_key..'/'..coord..'?lang=en&units=ca&exclude=hourly,flags"')
Edit: First line edited for grammar.
Last edited by alanlsmith on Thursday 13 December 2018 18:31, edited 2 times in total.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Kifo
Post by Kifo »
YES! That does the trick.
Thanks a lot, you saved my day (and my big domiticz installation).
EllaCarter
Post by EllaCarter »
Weather forecast is doe for the dark and depth of the sky. All the issues of the skies and buy custom essays are fully equipped for the forecast for the matters and all top class of the joys for the tam. This is enduring for the flexible means for humans.
