Its a bash command tool for remote control your TV over lan. You can use this for different TV Brands with Vestel Chassis.
Start bash script with an argument like ./toshiba.sh onAkai Crown Daewoo Dual Emerson Ferguson Funai Goranje Hitachi Horizon Hyundai ITT JVC Linsar Medion Tevion Lifetec
Nordmende Orion Palladium Panasonic CX Philips 32PFL3008 Polaroid RCA Saba Sanyo Toshiba Univerum
Install:
Copy to your Folder an give rights.
chmod +x toshiba.sh
edit toshiba.sh with your IP of TV
get start.
Commands which you can use are in the script. Its the Remote Control like.
#!/bin/bash
# Script zum ausführen von Kommandos über Ethnernet zu einem Toshiba LCD Fernseher (Vestel Chassis)
# Script to execute commands over Ethernet to Toshiba LCD Television (Vestel Chassis)
# Version 0.1 10.12.2018 Cihan Sahin Germany
#IP dem Fernseher anpassen
#Change IP to your TV
#Variablen
ip="http://192.168.0.108:56789/apps/SmartCenter" #Ziel Adresse des TV Targethost TV
#Programmstart
echo "Toshiba Lan Remote Control V0.01"
echo "$ip"
#Zielhostabfrage
if [ -n $ip ]
then
echo "Verbindung zu $ip wird hergestellt"
echo "Bitte zuerst die IP des TV eintragen."
fi
#Keycodes senden
case "$1" in
0) curl -X POST -d '<remote><key code=1000/></remote>' $ip
1) curl -X POST -d '<remote><key code=1001/></remote>' $ip
2) curl -X POST -d '<remote><key code=1002/></remote>' $ip
3) curl -X POST -d '<remote><key code=1003/></remote>' $ip
4) curl -X POST -d '<remote><key code=1004/></remote>' $ip
5) curl -X POST -d '<remote><key code=1005/></remote>' $ip
6) curl -X POST -d '<remote><key code=1006/></remote>' $ip
7) curl -X POST -d '<remote><key code=1007/></remote>' $ip
8) curl -X POST -d '<remote><key code=1008/></remote>' $ip
9) curl -X POST -d '<remote><key code=1009/></remote>' $ip
back) curl -X POST -d '<remote><key code=1010/></remote>' $ip
ratio) curl -X POST -d '<remote><key code=1011/></remote>' $ip
on) curl -X POST -d '<remote><key code=1012/></remote>' $ip
echo "Kommando On wird gesendet"
mute) curl -X POST -d '<remote><key code=1013/></remote>' $ip
lang) curl -X POST -d '<remote><key code=1015/></remote>' $ip
volup) curl -X POST -d '<remote><key code=1016/></remote>' $ip
voldown) curl -X POST -d '<remote><key code=1017/></remote>' $ip
info) curl -X POST -d '<remote><key code=1018/></remote>' $ip
down) curl -X POST -d '<remote><key code=1019/></remote>' $ip
up) curl -X POST -d '<remote><key code=1020/></remote>' $ip
left) curl -X POST -d '<remote><key code=1021/></remote>' $ip
right) curl -X POST -d '<remote><key code=1022/></remote>' $ip
stop) curl -X POST -d '<remote><key code=1024/></remote>' $ip
play) curl -X POST -d '<remote><key code=1025/></remote>' $ip
rewind) curl -X POST -d '<remote><key code=1027/></remote>' $ip
forward) curl -X POST -d '<remote><key code=1028/></remote>' $ip
sub) curl -X POST -d '<remote><key code=1031/></remote>' $ip
close) curl -X POST -d '<remote><key code=1037/></remote>' $ip
fav) curl -X POST -d '<remote><key code=1040/></remote>' $ip
timer) curl -X POST -d '<remote><key code=1042/></remote>' $ip
quick) curl -X POST -d '<remote><key code=1043/></remote>' $ip
app) curl -X POST -d '<remote><key code=1046/></remote>' $ip
epg) curl -X POST -d '<remote><key code=1047/></remote>' $ip
menu) curl -X POST -d '<remote><key code=1048/></remote>' $ip
pause) curl -X POST -d '<remote><key code=1049/></remote>' $ip
yellow) curl -X POST -d '<remote><key code=1050/></remote>' $ip
rec) curl -X POST -d '<remote><key code=1051/></remote>' $ip
blue) curl -X POST -d '<remote><key code=1052/></remote>' $ip
ok) curl -X POST -d '<remote><key code=1053/></remote>' $ip
green) curl -X POST -d '<remote><key code=1054/></remote>' $ip
red) curl -X POST -d '<remote><key code=1055/></remote>' $ip
input) curl -X POST -d '<remote><key code=1056/></remote>' $ip
mediabrowser) curl -X POST -d '<remote><key code=1057/></remote>' $ip
text) curl -X POST -d '<remote><key code=1255/></remote>' $ip
presets) curl -X POST -d '<remote><key code=1014/></remote>' $ip
progup) curl -X POST -d '<remote><key code=1032/></remote>' $ip
progdown) curl -X POST -d '<remote><key code=1033/></remote>' $ip
swap) curl -X POST -d '<remote><key code=1034/></remote>' $ip
channel) curl -X POST -d '<remote><key code=1045/></remote>' $ip
esac
