'On action' runs bash but no 433Mhz signal
Cyroq
Post by Cyroq »
I've hooked a 433MHz transmitter to my RasPi3 (DATA is on pin 14(BCM) / TxD / 8 (physical) / 15 (wPi)). In /etc/init.d/domoticz.sh I've added the line
/usr/local/bin/gpio export 14 out
I also installed a set of pre-set scripts that control different brands of 433MHz switches, such as KlikAanKlikUit. I can successfully control such a switch from the command line with
./home/pi/wiringPi/examples/lights/kaku 1 A on
I created a bash script in domoticz/scripts:
#!/bin/bash
echo 'script executed'> /home/pi/temp/test.log
In Domoticz, I added a manual switch with the correct path to this bash script after 'On action'. I can see it working, because test.log shows 'script executed' when I hit the virtual switch.
However, there is no 433MHz signal / the switch isn't triggered. Could it be a permission problem? Or is it something else?
Hope you guys can help me out!
Re: 'On action' runs bash but no 433Mhz signal
Cyroq wrote: Monday 10 December 2018 13:58
#!/bin/bash
Can be permission but can also be because you are using a relative path. Try to make this path absolute. ( /home/pi/wiringPi/examples/lights/kaku 1 A on ) so without the starting dot
First try that and when still problems change the permissions.
Cyroq
Post by Cyroq »
Well, I guess that shows I'm still quite a beginner at this stuff :roll: Removing the dot did the trick, thanks mate!
