[Script] Report devices online status
Chopper_Rob
Post by Chopper_Rob »
I see a lot of topics from other users who are trying to create scripts for monitoring network devices, so i would like to share my python script. This way not everybody has to build the same thing and they can focus on some other cool scripts. ;)
This script uses ping to monitor a device on the network.
To reduce the number of false positives i added a 'cooldown' period.
So if a device goes offline it is not immediately reported back to domoticz, it waits to see if the device comes back online before the cooldown period expires.
This is very useful if you want to use your phone to determine if you are at home. For example, an iPhone is not always connected to the network when it is locked, especially at night it can be "offline" for 45 minutes before it returns on the network. Without the cooldown period domoticz will get a lot of fake reports and it could be switching devices off when your still at home.
Before reporting a change in the online/offline status, the script first checks the current status of the switch in Domoticz. If the switch already has the correct status it won't reset it, this prevents triggering domoticz events for a second time.
You can find the script here : http://www.chopperrob.nl/domoticz/5-rep ... o-domoticz
I hope you like it.
Mince Inside
Re: [Script] Report devices online status
Post by Mince Inside »
Nice script - have you read about the iBeacon and this bad boy? https://learn.adafruit.com/pibeacon-ibe ... i/overview. Dont know if it's just as prone to the iPhone going AWOL
Domoticz V2.2259
Raspberry Pi (B) with PiFace
RFXtrx433 USB
LighwaveRF relays, dimmer bulbs and light switches
Siemens On/Off 13A adaptors
Marmitek MS13E Motion (and Dusk) sensors
blackdog65
Post by blackdog65 »
Hiya,
I've been using this script quite happily and it has been working fine, however I've had the password enabled
# Settings for the domoticz server
domoticzserver="192.168.xx.xx:8080"
domoticzusername = "xxxxx"
domoticzpassword = "xxxxx"
A different script that I'm experimenting with currently doesn't run WITH password enabled...
so my question is... how do I disable check_device_online.py needing a password?
I tried leaving Un and Pw blank, commenting them out but no luck
Any ideas?
thanks
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
simonrg
Domoticz version: 3.8807
Post by simonrg »
Why are you using a script for this?
When this functionality is built into Domoticz.
blackdog65
I was using it before it was added to Domoticz. I did have a little play with the new system and it was a bit iffy. Telling me I wasn't there when I obviously was... as I was reading the screen :shock:
Although in honesty, I probably didn't have the time and patience to get the settings right. If you have something that's working it's a case of "If it ain't broke, don't fix it" ;)
I may have to rethink though order to use moshel's script
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Chopper_Rob
When the script is running on the same machine as domoticz you can use the ip adress 127.0.0.1 in the settings. This way you don't need to enter the credentials.
galadril
Domoticz version: latest
Post by galadril »
Script is not found anymore?
tozzke
Domoticz version: Stable
Post by tozzke »
galadril wrote:Script is not found anymore?
I believe it's the same as the wiki (although the wiki has some minor tweaks)
