Operate power values
Sergio
Domoticz version: 3.9639
Post by Sergio »
I'm trying to process the values of several power devices to find the difference. Is there a way to directly get the Watts value of a power (usage) sensor without manually fiddling with separators? Like value = otherdevices['Lighting'][0].Value
What I'm trying to calculate is:
    total = otherdevices['total'].Value
    lights = otherdevices['lights'].Value
    kitchen= otherdevices['kitchen'].Value
    plugs = otherdevices['plugs'].Value
    parasitic = total - lights - plugs - kitchen
    commandArray['UpdateDevice'] = idx..'|0|'..parasitic
Siewert308SW
Domoticz version: Stable
Re: Operate power values
Post by Siewert308SW »
Something like this?
Use the following function for my events to see if someone is using a device or not.
But could also serve your purpose, i think.
It aint tested but should give you a headstart.
You could also include the "parasitic = total - lights - plugs - kitchen" into the function to make it cleaner
	function powerusage(powerplug)
		local powerplug = powerplug
		local reading
		local usage
			  reading = otherdevices[powerplug]
			_,_,usage = string.find(reading, "(.+)")
		  current_usage = tonumber(reading)
		  return current_usage
    total = powerusage['total']
    lights = powerusage['lights']
    kitchen=powerusage['kitchen']
    plugs = powerusage['plugs']
    commandArray['UpdateDevice']=tostring(parasitic)
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Sergio
Post by Sergio »
Thanks siewert for your help. I just found in the stickies a file for custom functions that includes an array parser that serves my purpose. I'm doing tests.
Anyways, thank you.
Enviado desde mi MI 5s Plus mediante Tapatalk
