right now i am testing to install an heater control for the whole house. While i am doing some evaluation - dry run. I had the following effect when steering the valves of the Wallheaters.
In the first version i implemented an logic like - if temp goes below point then valve on - to haet and so on. Works fine but.
if the incoming temp is like 0.1 degress changing the valve goes on and then off / on /off /off so it flaps for measuring tolerance.
The Idea was now to say - lets check the temp over a period of time like 2 minutes and if the temp continuously stays below.... then set a switch so that the heating valve will get on.
The question is now - Is there a simple way in domoticz to measure a value over a period of time like in that graphical stats shown. There must be some access to this data? or just measuring - maybe an lua script may do something.
Thank You - for ideas
