help with dzventsscript
pvklink
Domoticz version: latest b
Post by pvklink »
Hi, i tried to read temperaturesensor based on weatherunderground. Got it almost working.
I get an error on variable prevwaarde, it seems to have no value?
- I added a initial value of 100 in the data section and
- i checked if this global variable is empty and set it to 100
Both dont seemed to work...
2018-11-21 09:37:15.671 Status: dzVents: Info: 00 Sensor device = Zuiderparklaan
2018-11-21 09:37:15.671 Status: dzVents: Info: 00 Sensor id to update = 826
2018-11-21 09:37:15.671 Status: dzVents: Info: 00 Sensor grenswaarde = 2
2018-11-21 09:37:15.671 Status: dzVents: Info: 00 Sensor huidige waarde= 2.4000000953674
2018-11-21 09:37:15.671 Status: dzVents: Error (2.4.8): An error occured when calling event handler test2
2018-11-21 09:37:15.671 Status: dzVents: Error (2.4.8): .../pi/domoticz/scripts/dzVents/generated_scripts/test2.lua:33: attempt to index global 'domoticz' (a nil value)
-- soon more sensor temp device will be added to this script
local TMP_DEVICES = {
    ['Zuiderparklaan'] = 'Zuiderparklaan',                      -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_tmpnorm = {
    ['Zuiderparklaan'] = 2,                                     -- Adjust to your needs. Between every line you need to add a ",".
    on = { devices = TMP_DEVICES },
    logging = { level   = domoticz.LOG_DEBUG ,                  -- Uncomment to override the dzVents global logging setting
                marker  = actOnIdleDevices
    data = {
          prevhistwaarde = { history = true, maxItems = 10, initial=100 }
    execute = function(dz, device)
    local name          = device.name
    local norm          = USAGE_tmpnorm[TMP_DEVICES[name]]
    local huidwaarde    = device.temperature
    --function round2(num, numDecimalPlaces)
        --return tonumber(string.format("%." .. (numDecimalPlaces or 0) .. "f", num))
    -- end
    if dz.data.prevhistwaarde[name] == nil then
        dz.log("00 Sensor info         = Geen vorige waarde opgehaald")
        local prevwaarde    = 100
        local prevwaarde    = dz.data.prevhistwaarde[name]
    dz.log("00 Sensor device        = " .. name)
    dz.log("00 Sensor grenswaarde   = " .. norm)
    dz.log("00 Sensor huidige waarde= " .. tostring(huidwaarde))
    dz.log("00 Sensor vorige waarde = " .. tostring(prevwaarde))
    dz.log("---------------------------------------")
    if huidwaarde == nil then
        dz.log("01 Sensor info         = Geen waarde opgehaald")
        if (huidwaarde - prevwaarde == 0 ) then
            dz.log("02 Sensor info         = Oude en nieuwe sensorwaarden zijn gelijk")
            dz.log("03 Sensor info         = Nieuwe sensorwaarde...")
        	domoticz.devices('temperatuur').updateTemperature(huidwaarde)
            domoticz.data.prevhistwaarde.add(huidwaarde)
Jablotron connection, Ikea
Re: help with dzventsscript
pvklink wrote: Wednesday 21 November 2018 17:09 Hi, i tried to read temperaturesensor based on weatherunderground. Got it almost working.
33        local prevwaarde    = dz.data.prevhistwaarde[name]
prevhistwaarde is not defined as a global variable but as a historical persistent variable
Line 33 is not according to the syntaxis for historical persistent data
Can you try with
        local prevwaarde    = dz.data.prevhistwaarde.getLatest() or 0
pvklink
Post by pvklink »
Ok, Script performs better.
Get the following error
4:33.083 Status: dzVents: Info: ------ Start internal script: DZ_testmettemperatuur: Device: "Zuiderparklaan (weather underground rijswijk)", Index: 680
2018-11-21 20:54:33.084 Status: dzVents: Info: 00 Sensor device = Zuiderparklaan
2018-11-21 20:54:33.084 Status: dzVents: Info: 00 Sensor grenswaarde = 2
2018-11-21 20:54:33.084 Status: dzVents: Info: 00 Sensor huidige waarde= 4.2
2018-11-21 20:54:33.085 Status: dzVents: Info: 00 Sensor vorige waarde = table: 0x6378df70
2018-11-21 20:54:33.085 Status: dzVents: Info: ---------------------------------------
2018-11-21 20:54:33.085 Status: dzVents: Error (2.4.8): An error occured when calling event handler DZ_testmettemperatuur
2018-11-21 20:54:33.085 Status: dzVents: Error (2.4.8): ...ipts/dzVents/generated_scripts/DZ_testmettemperatuur.lua:54: attempt to perform arithmetic on local 'prevwaarde' (a table value)
2018-11-21 20:54:33.085 Status: dzVents: Info: ------ Finished DZ_testmettemperatuur
I made some adjustsments, this is the current script. feel free to change, i am not a programmer, trying hard to get it to work :oops:
1) dz.log("00 Sensor vorige waarde = " .. tostring(prevwaarde)) --> gives a strange format
2) prevhistwaarde = { history = true, maxItems = 10, initial = 100 } -->default no 100 in the historic_data,
3) how to reset the historic data when starting the script the first time
4) how can i check the values in the historic data so i can log historic temp values
5) if prevwaarde == nil then
end does not seems to work
-- wordt de vervanger van dz_buitentemperatuur
-- https://github.com/dannybloe/dzVents#historical-variables-api
-- script uses a temp sensor Zuiderparklaan which uses Weather Underground with pws:ITHEHAGU40
    data = {
    local huidwaarde    = round2(device.temperature,1)
--    local prevwaarde    = dz.data.prevhistwaarde.getLatest()    round function does not work on table data, this variable is useless.. how to convert to a number round2 function does not work here
    --dz.log("00 History data         = " .. tostring(dz.data.prevhistwaarde))
            dz.log("02 Sensor info         = Nieuwe sensorwaarde...")
            dz.devices('Temperatuur').updateTemperature(huidwaarde)
            dz.data.prevhistwaarde.add(huidwaarde)
                dz.log("03 Sensor info         = Oude en nieuwe sensorwaarden zijn gelijk")
            elseif (huidwaarde - prevwaarde > 0 ) then
                dz.log("04 Sensor info         = Temperatuur stijgt")
                dz.log("05 Sensor info         = Temperatuur daalt")
datafile
-- Persistent Data
local multiRefObjects = {
} -- multiRefObjects
local obj1 = {
	["prevhistwaarde"] = {
		[1] = {
			["data"] = 4.9000000953674;
			["time"] = "2018-11-21 17:54:26.851";
return obj1
pvklink wrote: Wednesday 21 November 2018 18:28 I made some adjustsments, this is the current script. feel free to change
Something like this ?
--[[ wordt de vervanger van dz_buitentemperatuur
      https://github.com/dannybloe/dzVents#historical-variables-api <<<<< This is quite old ; better use
      https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#Accessing_values_in_historical_variables
    logging =   {
                    marker  = "Temperatuur trend"
    data    =   {
                    prevhistwaarde = { history = true, maxItems = 10 }
        if dz.data.prevhistwaarde.getOldest() == nil then  -- Check if history is already filled (initial does not work with history persistent data
          dz.data.prevhistwaarde.add(100)
        local huidwaarde    = dz.utils.round(device.temperature,1)
        local prevwaarde    = dz.utils.round(dz.data.prevhistwaarde.getLatest().data,1)
        dz.log("00 Sensor huidige waarde= " .. huidwaarde)
        dz.log("00 Sensor vorige waarde = " .. prevwaarde)
        dz.log(dz.data.prevhistwaarde.size )
        for i = dz.data.prevhistwaarde.size,1,-1 do
            item = dz.data.prevhistwaarde.get(i)
            dz.log("00 History data van " .. item.time.rawDate .. " " .. item.time.rawTime ..
                                    " = " .. item.data .. " graden")
            if huidwaarde == prevwaarde then
                return
            if huidwaarde > prevwaarde then
            elseif huidwaarde < prevwaarde then
            dz.devices('Temperatuur2').updateTemperature(huidwaarde)
pvklink
Post by pvklink »
you are amazing!
I (you, sorry) made this script for my 85 years old father in law how lives on a houseboat. In the winter his watersuply freezes. So we bought an electric wire to warm it. We connect the wire to a smart switch/sensor. A made two lua scripts for him, one to check the temp, one to activate the switch with some rules so that the switch does not goes on or off to much. I want to get rid of LUA....because dzvents is much smarter i think...
If temp is below 4 switch must go on for x hours, but if the temp is above 4 it must go off if the timeperiod x hours is over...
[logging]
19:35:50.776 (weather underground rijswijk) General/Visibility (Zuiderparklaan-Zicht)
2018-11-22 19:35:50.779 (weather underground rijswijk) General/Solar Radiation (Zuiderparklaan6)
2018-11-22 19:35:50.845 Status: dzVents: Info: Temperatuur trend: ------ Start internal script: DZ_testmettemperatuur: Device: "Zuiderparklaan (weather underground rijswijk)", Index: 680
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 00 Sensor device = Zuiderparklaan
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 00 Sensor grenswaarde = 4
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 00 Sensor huidige waarde= 4.6
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 00 Sensor vorige waarde = 4.9
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 1
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 00 History data van 2018-11-21 18:54:26 = 4.9000000953674 graden
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: ---------------------------------------
2018-11-22 19:35:50.846 Status: dzVents: Info: Temperatuur trend: 05 Sensor info = Temperatuur daalt
2018-11-22 19:35:50.848 Status: dzVents: Debug: Temperatuur trend: Processing device-adapter for Temperatuur: Temperature device adapter
2018-11-22 19:35:50.850 Status: dzVents: Info: Temperatuur trend: ------ Finished DZ_testmettemperatuur
[old lua script_1] the new temperature dzvents script will replace this one/
--Script To Parse WeatherUnderground Multi-Value Sensor, Additionally using PWS: system from WU with a new output format
--This script assumes the output (which can be viewed in events show current state button) is like this 19.5;79;3;1019;3 (temp;humidity;null;pressure;null)
--more details at this wiki http://www.domoticz.com/wiki/Virtual_weather_devices
--The following need updated for your environment get the 'Idx' or 'Name' off the Device tab. By default only the Temp is 'uncommented or enabled' in this script.
local sensorwu = 'Barometer' --name of the sensor that gets created when you add the WU device (and that contains multiple values like temperature, humidity, barometer etc)
local idxt = 394 --idx of the virtual temperature sensor you need to change this to your own Device IDx
--local idxh = 999 --idx of the virtual humidity sensor you need to change this to your own Device IDx
--local idxp = 999 --idx of the virtual pressure sensor you need to change this to your own Device IDx
if devicechanged[sensorwu] then
        sWeatherTemp, sWeatherHumidity, sWeatherPressure = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+);([^;]+)")
        sWeatherTemp = tonumber(sWeatherTemp)
        commandArray[1] = {['UpdateDevice'] = idxt .. '|0|' .. sWeatherTemp}
    if sWeatherTemp > 3 then
        print ('Temperatuur groter dan 3, warmtelint uit')
        commandArray['warmtelint']='Off'
        print ('Temperatuur <= dan 3, warmtelint aan')
        commandArray['warmtelint']='On'
    print("waarde sensor: "..tostring(sWeatherTemp)..'xx')
[old lua script_2] For this script i made a new dzvents script
local switchlint = 'warmtelint'             -- schakelaar die bij onderschreiding temperatuur aangezet wordt
local switchverbruik = 'Verbruikwarmtelint'             -- schakelaar die bij onderschreiding temperatuur aangezet wordt
local curwatlimit = 1                       -- minimale onderwaarde temperatuur
local wacht=2000
    curwat = otherdevices_svalues["Verbruikwarmtelint"]
    print ('07a Stroomlintverbruik heeft waarde' .. tonumber(curwat) .. '/')
    curwat=0
if devicechanged[switchlint] == 'On' then
    i = 1
    while i  <= wacht do
        ping_success=os.execute('ping -c1 -w 1 192.168.20.1')
        print ('teller:'..tostring(i)..'')
	    i = i + 1
    if tonumber(curwat) > tonumber(curwatlimit) then            -- lint gebruikt stroom, dus werkt
        print ('07 Stroomlint werkt. Verbruikt ' .. curwat)
        print ('07 Stroomlint werkt niet. Verbruikt ' .. curwat)
I made a new dzventz script for the switch as well...
    	active = true,
        timer = {'every 60 minutes'}                                             -- dit mag wel een uur worden
execute = function(domoticz)
    local scriptnaam = 'Verbruikwarmtelint'                                     -- naam script voor de foutmelding
    local switchlint = 'fibaro'                                             -- schakelaar die bij onderschreiding temperatuur aangezet wordt
    local switchverbruik = 'Verbruikfibaro'                                 -- sensor die verbruik van de schakelaar meet
    local curwatlimit = 1                                                       -- minimale onderwaarde wattage van het warmtelint (onder deze waarde is hij defect)
    local curwat = tonumber(domoticz.devices(switchverbruik).WhActual)          -- wattage van het apparaat dat aan de switch is gekoppeld, het feitelijke warmtelint
    if domoticz.devices(switchlint).state == 'On' then
        if tonumber(curwat) > tonumber(curwatlimit) then                        -- lint gebruikt stroom, meer dan de normwaarde, dus werkt
            domoticz.log('PRG: ' ..scriptnaam ..': stroomlint werkt, verbruikt: ' .. curwat .. ' Watt')
        else        -- lint onder de normale verbruikswaarde (nog n PUSHNOTIFICATIE maken
            domoticz.log('PRG: ' ..scriptnaam ..': stroomlint werkt niet, of thermo staat aan! meet geen stroom!' .. curwat .. ' Watt')
pvklink wrote: Thursday 22 November 2018 19:20 I made this script for my 85 years old father in law how lives on a houseboat. In the winter his watersuply freezes. So we bought an electric wire to warm it. We connect the wire to a smart switch/sensor. A made two lua scripts for him, one to check the temp, one to activate the switch with some rules so that the switch does not goes on or off to much. I want to get rid of LUA....because dzvents is much smarter i think...
That sounds like a very good reason to use domoticz. Glad I could point you in the direction of a working script. Feel free to ask for clarification or help when needed !
pvklink
Post by pvklink »
And this is the result.
I used a dummyswitch sonoff1 to simulate a switch with a thermostatic heating device
the USAGE_durtimer isnt used. I use an average temperature:
local gemwaarden = dz.utils.round(dz.data.prevhistwaarde.avgSince('00:15:00'),1)
-[[ wordt de vervanger van dz_buitentemperatuur aanzetten van lint en een timer om aan uit te voorkomen..
local USAGE_SENSORS =     {
    ['Zuiderparklaan-Diversen'] = 'Zuiderparklaan-Diversen',  -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_SWITCHES = {
    ['Zuiderparklaan-Diversen'] = 'Sonoff1',                     -- Name of device that switch kw_1 On/ Off
local USAGE_norm =   {
    ['Zuiderparklaan-Diversen'] = 4,                 -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_DurTimer = {
    ['Zuiderparklaan-Diversen'] = 20,                   --
local USAGE_SwitchOnOff = {
    ['Zuiderparklaan-Diversen'] = 'Yes',                -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_Notify = {
local USAGE_Pushoverreceivers = {
    ['Zuiderparklaan-Diversen'] = 'xxx',
local USAGE_Pushoversound = {
    ['Zuiderparklaan-Diversen'] = 'bike',
    on      =   {   devices = USAGE_SENSORS },
    logging =   {
    data    =   {
                    prevhistwaarde = { history = true,  maxHours = 1 },
                    sendnotification = {initial = {}},
        local name2         = USAGE_SWITCHES[name]
        local switch        = dz.devices(USAGE_SWITCHES[name])
        local onoff         = USAGE_SwitchOnOff[USAGE_SENSORS[name]]
        local notify        = USAGE_Notify[USAGE_SENSORS[name]]
        local receivers     = USAGE_Pushoverreceivers[USAGE_SENSORS[name]]
        local sound         = USAGE_Pushoversound[USAGE_SENSORS[name]]
        local norm          = USAGE_norm[USAGE_SENSORS[name]]
        local DurTimer      = USAGE_DurTimer[USAGE_SENSORS[name]]
        local avgwaarde     = dz.utils.round(dz.data.prevhistwaarde.avg(),1)
        local minwaarde     = dz.utils.round(dz.data.prevhistwaarde.min(),1)
        local maxwaarde     = dz.utils.round(dz.data.prevhistwaarde.max(),1)
        if dz.data.sendnotification[name] == nil then
            dz.data.sendnotification[name] = false       -- eerste waarde teller op false gezet  -- geen notify gedaan
        dz.log("00 Sensor switch device = " .. name2)
        dz.log("00 Sensor onoff         = " .. onoff)
        dz.log("00 Sensor notify        = " .. notify)
        dz.log("00 Sensor receivers     = " .. receivers)
        dz.log("00 Sensor sound         = " .. sound)
        dz.log("-------------------------------------------------")
        dz.log("00 Sensor notif. norm   = " .. DurTimer)
        dz.log("00 Sensor gemid. 5min   = " .. gemwaarden)
        dz.log("00 Sensor gemid. hist   = " .. avgwaarde)
        dz.log("00 Sensor minimum waarde= " .. minwaarde)
        dz.log("00 Sensor maximum waarde= " .. maxwaarde)
        dz.log("00 Status notificatie   = " .. tostring(dz.data.sendnotification[name]))
    if  gemwaarden > norm then
        dz.log("01 Sensor info         = Huidig gemiddelde temperatuur (".. gemwaarden ..") is boven de norm(".. norm .. "), device: " .. name ..  "")
        if switch.state == 'On' and onoff == 'Yes' then
                    switch.switchOff().checkFirst().silent()
        dz.log("02 Sensor info         = Huidig gemiddelde temperatuur (".. gemwaarden ..") is onder of gelijk aan de norm(".. norm .. "), device: " .. name ..  "")
        if switch.state == 'Off' and onoff == 'Yes' then
            switch.switchOn().checkFirst().silent()
        if notify == 'Yes' and (dz.data.sendnotification[name] == false) then
            dz.notify('03 Sensor info         = Huidig gemiddelde temperatuur ('.. gemwaarden .. ') van device:' .. name2 .. ' is lange tijd('.. tostring(DurTimer) .. '), onder de norm('.. norm .. ')',
            name,PRIORITY_NORMAL,sound,receivers,dz.NSS_PUSHOVER)
            dz.data.sendnotification[name] = true       -- eerste waarde teller op 0 gezet  -- registreren dat notificatie is gedaan
    --dz.devices('Temperatuur').updateTemperature(huidwaarde)
I also have a script for checking the thermodevice is realy working my measuring its usage....
