Hello all,
I want to connect from domoticz to my node-red instance on the same RPI to control some MQTT systems.
I need to do this preferably from a LUA script. Does anyone have a good simple example of how to publish an mqtt message?
I understand from partial hints and wikis that it should be done with
CommandArray['OpenURL']= and then a JSON line. But I have not been able to find a working example to start experimenting from.
Any help is appreciated.
Bert
LUA command to publish MQTT message
brjhaverkamp
- emme
- Domoticz version: latest
Re: LUA command to publish MQTT message
first install mosquitto_clients
then in your script you can use:
sudo apt-get install mosquitto_pubCode: Select all
os.execute('mosquitto_pub -h 127.0.0.1 -t my/topic -m '..myPayload)The most dangerous phrase in any language is:
"We always done this way"
