Page 1 of 9
There is Somfy in the air!!
Posted: Friday 23 May 2014 11:34
by remb0
Great news about controlling Somfy motors,
We got lots of qeustions for supporting somfy, and now we got an great answer!
The RFXtrx433E become available from June 2 2014.
RFXtrx433E is A succesor of the great RFXtrx433 with the possibility to control Somfy motors.
We already got an prototype from rfxcom.com to implement and test.
And the Domoticz team has build in support (from beta 1772)
I have tested it and it works great!!
You are able to add a manual switch,
Give it a name, Choose type RFY (the name of Somfy in Domoticz)
Set a random unique Id and Unit,
Click test to pair and Add device.
The RFXtrx433E is available: http://www.rfxcom.com/Downloads
and Hardware: http://www.rfxcom.com/store/Sender%20un ... nger/14103
Re: There is Somfy in the air!!
Posted: Sunday 25 May 2014 23:20
by darrepac
Argh!! I bought my RFXTRX some weeks ago without being aware of this upcoming RFXTRX "E" version with RFY support!
Would be interesting to know if the added HW can be added to previous model...
Posted: Monday 26 May 2014 22:26
by drogert
I also bought the RFXTRX433. Can you explain the difference between the normal and the "E" other then support for RFY? Can it recieve multiple protocols like lighting4 and ARC at the same time for instance? Or is this not possible in any way?
Posted: Monday 26 May 2014 22:40
by darrepac
I have external venetian blinds controlled with Telis var/mod remote (this the one with a rolling button in the middle to choose the angle of the vrnetian). Is Domoticz capable to change venitian angle or just "up" , "down" and "my"?
Posted: Monday 26 May 2014 23:02
by b_weijenberg
@drogert: The RFXtrx433E can use Type1, Type2 and Ext firmware. The RFxtrx433 can use Type1 or Type2. See the RFXtrx433 User Guide chapter 2
@darrepac: the RFXtrx433E supports "up" , "down" and "my".
Posted: Wednesday 28 May 2014 9:22
by Omehenne
Is there more news on the 868mhz version?
Posted: Wednesday 28 May 2014 20:55
by TANE
Somfy control works great.
Also controlling from the HC2.
http://forum.fibaro.com/viewtopic.php?t=4390
Posted: Sunday 01 June 2014 20:11
by Andyyyy
no way to pimp my RFXtrx433 to an RFXtrx433E ??
Posted: Monday 02 June 2014 9:28
by b_weijenberg
There is no upgrade kit for the RFXtrx433.
Posted: Thursday 12 June 2014 12:28
by xKingx
Managed to get my Somfy sunscreen working using an RFXtrx433E. Good stuff!
Posted: Thursday 12 June 2014 17:54
by darrepac
How to make the choice between blinds, blinds inverted, blinds percentage?
thanks
Posted: Saturday 14 June 2014 17:37
by Steven84
Can't get it working.... chose random ID & Unit but nothing?
Posted: Saturday 14 June 2014 17:49
by b_weijenberg
Did you follow the procedure described in the RFXtrx User Guide?
Posted: Sunday 15 June 2014 12:17
by Steven84
b_weijenberg wrote:Did you follow the procedure described in the RFXtrx User Guide?
First i didn't then in followed it and succes!
Thanx Weijenberg!
Posted: Wednesday 25 June 2014 14:16
by triathlete78130
Hi Team,
I have installed the RFXTrx433E and can perfectly control my 13 Blinds.
The Up, Down, and Stop button works exactly like the remote control. (the Stop button beeing the My button)
Nevertheless, when I do scenario, I can only do On/Off and not use the Stop Button... and it works as designed.
How can I do to add the functionality Stop and not only on/off in the scenario definition?
Posted: Thursday 26 June 2014 14:06
by b_weijenberg
A new firmware version 227 for the RFXtrx433E is available on the RFXCOM download page.
Changes:
Some Somfy RTS motors did not respond correctly on up/down commands.
The maximum number of simulated RTS remotes is increased from 16 to 30.
Somfy RTS venetian blinds device added. (not yet available in Domoticz)
Other changes:
Viking checksum added
Conrad RSL improved
BTHR968 forecast corrected
RTHN318 corrected
DM10 corrected
LightwaveRF Off corrected
Prego P-8426 sensor added
Kambrook, Rubicson and Viking supported in EXT firmware.
Posted: Thursday 26 June 2014 14:26
by laurent207
I have domoticz v1.1812 on my rasberry with a RFXtrx433E but I don't have RFY type. Under windows it works great. Do you have a tips to have RFY type on domotics on a respberry pi ?
Posted: Thursday 26 June 2014 14:27
by b_weijenberg
check the beta version
Posted: Thursday 26 June 2014 14:30
by laurent207
how ? I install domoticz on my raspbian thanks to the domoticz's wiki.
Posted: Thursday 26 June 2014 16:37
by triathlete78130
b_weijenberg wrote:A new firmware version 227 for the RFXtrx433E is available on the RFXCOM download page.
Changes:
How can we do add the My/Stop button working fine in the light pannel in the script and planning possibility (On/Off)?
