ERROR: Dropping command, expected response not received after 1 attempt(s)
paulp852
Domoticz version: 4.9701
Post by paulp852 »
System: QNAP TS-253A
Domoticz Version: 4.9701
Build Hash: b47a877f
Compile Date: 2018-06-23 16:27:56
dzVents Version: 2.4.6
Python Version: None
Nodes:
Node Id Basic Type Generic Type Product Name
1 *LB Static Controller Static PC Controller Aeotec ZW090 Z-Stick Gen5 EU Controller
7 LBR+ Z-Wave+ node Always On Slave On/Off Power Switch Devolo home Control Metering Plug MT02646
8 LBR+ Z-Wave+ node Always On Slave On/Off Power Switch FIBARO System FGWPE/F Wall Plug Gen5
16 BR+ Z-Wave+ node Reporting Sleeping Slave Smoke Alarm Sensor FIBARO System FGSD002 Smoke Sensor
17 BR+ Z-Wave+ node Reporting Sleeping Slave Smoke Alarm Sensor Devolo home Control Unknown: type=2004, id=04a4
19 BR+ Z-Wave+ node Reporting Sleeping Slave Smoke Alarm Sensor FIBARO System FGSD002 Smoke Sensor
For all nodes (except Aeotec ZW090 Z-Stick Gen5 EU) the following error is registrated in the log:
2018-11-08 21:07:21.066 Error, Node016, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-08 21:07:21.066 Always,
2018-11-08 21:07:21.066 Always, Dumping queued log messages
2018-11-08 21:07:21.066 Always, End of queued log message dump
Debugging log:
2018-11-08 21:24:11.097 Error, Node008, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-08 21:24:11.097 Always,
2018-11-08 21:24:11.097 Always, Dumping queued log messages
2018-11-08 21:24:11.097 Always, End of queued log message dump
2018-11-08 21:24:11.098 Always,
2018-11-08 21:24:11.098 Detail, Node008, Removing current message
2018-11-08 21:24:11.098 Detail, Node008, Notification: Notification - TimeOut
2018-11-08 21:24:11.098 Info, Node008, Sending (Query) message (Callback ID=0x51, Expected Reply=0x04) - PowerlevelCmd_Get (Node=8): 0x01, 0x09, 0x00, 0x13, 0x08, 0x02, 0x73, 0x02, 0x25, 0x51, 0xea
2018-11-08 21:24:11.105 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.105 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.126 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x51, 0x00, 0x00, 0x03, 0xb9
2018-11-08 21:24:11.126 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x51 received (expected 0x51)
2018-11-08 21:24:11.126 Info, Node008, Request RTT 27 Average Request RTT 44
2018-11-08 21:24:11.126 Detail, Expected callbackId was received
2018-11-08 21:24:11.140 Detail, Node008, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x08, 0x04, 0x73, 0x03, 0x00, 0x00, 0x8d
2018-11-08 21:24:11.140 Info, Node008, Response RTT 41 Average Response RTT 94
2018-11-08 21:24:11.140 Info, Node008, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
2018-11-08 21:24:11.140 Detail, Node008, Initial read of value
2018-11-08 21:24:11.140 Detail, Node008, Expected reply and command class was received
2018-11-08 21:24:11.140 Detail, Node008, Message transaction complete
2018-11-08 21:24:11.140 Detail, Node008, Removing current message
2018-11-08 21:24:11.140 Detail, Node008, Notification: ValueChanged
2018-11-08 21:24:11.140 Detail, Node008, Query Stage Complete (Session)
2018-11-08 21:24:11.140 Detail, Node008, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2018-11-08 21:24:11.140 Detail, Node008, QueryStage_Dynamic
2018-11-08 21:24:11.140 Detail, Node008, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SWITCH_BINARY
2018-11-08 21:24:11.140 Detail, Node008, Queuing (Send) SwitchBinaryCmd_Get (Node=8): 0x01, 0x09, 0x00, 0x13, 0x08, 0x02, 0x25, 0x02, 0x25, 0x5a, 0xb7
2018-11-08 21:24:11.140 Detail, Node008, Queuing (Send) SensorMultilevelCmd_Get (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x31, 0x04, 0x04, 0x25, 0x5b, 0xa2
2018-11-08 21:24:11.140 Detail, Node008, Queuing (Send) MeterCmd_Get (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x32, 0x01, 0x00, 0x25, 0x5c, 0xa7
2018-11-08 21:24:11.140 Detail, Node008, Queuing (Send) MeterCmd_Get (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x32, 0x01, 0x10, 0x25, 0x5d, 0xb6
2018-11-08 21:24:11.140 Detail, Node008, Queuing (Send) AlarmCmd_Get (Node=8): 0x01, 0x0c, 0x00, 0x13, 0x08, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x5e, 0xea
2018-11-08 21:24:11.140 Detail, Node008, Queuing (Query) Query Stage Complete (Dynamic)
2018-11-08 21:24:11.140 Info, Node008, Processing (Send) Nonce Request message (Callback ID=0x5a, Expected Reply=0x04)
2018-11-08 21:24:11.140 Info, Node008, Sending (Send) message (Callback ID=0x5a, Expected Reply=0x04) - Nonce_Get(SwitchBinaryCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x08, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-08 21:24:11.148 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.148 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.169 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x03, 0xea
2018-11-08 21:24:11.169 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-08 21:24:11.169 Info, Node008, Request RTT 28 Average Request RTT 36
2018-11-08 21:24:11.185 Detail, Node008, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x08, 0x0a, 0x98, 0x80, 0xc1, 0x12, 0x54, 0x62, 0x86, 0x87, 0x0b, 0x66, 0x78
2018-11-08 21:24:11.185 Info, Node008, Received SecurityCmd_NonceReport from node 8
2018-11-08 21:24:11.185 Info, Node008, Sending (Send) message (Callback ID=0x5f, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=8): 0x01, 0x09, 0x00, 0x13, 0x08, 0x02, 0x25, 0x02, 0x25, 0x5f, 0xb2
2018-11-08 21:24:11.195 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.195 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.221 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x5f, 0x00, 0x00, 0x03, 0xb7
2018-11-08 21:24:11.221 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x5f received (expected 0x5f)
2018-11-08 21:24:11.221 Info, Node008, Request RTT 80 Average Request RTT 58
2018-11-08 21:24:11.221 Detail, Expected callbackId was received
2018-11-08 21:24:11.235 Detail, Node008, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x08, 0x02, 0x98, 0x40, 0x21
2018-11-08 21:24:11.235 Info, Node008, Received SecurityCmd_NonceGet from node 8
2018-11-08 21:24:11.235 Info, NONCES: 0x0b, 0xfc, 0xe3, 0x40, 0xeb, 0x23, 0x7e, 0x3d
2018-11-08 21:24:11.235 Info, NONCES: 0x9f, 0x47, 0xf9, 0x96, 0xd3, 0x71, 0x4e, 0x31
2018-11-08 21:24:11.235 Info, NONCES: 0x50, 0xb9, 0x79, 0x3b, 0xdd, 0xf8, 0x79, 0x5a
2018-11-08 21:24:11.235 Info, NONCES: 0xf0, 0x9a, 0x41, 0xc4, 0x0b, 0x8f, 0xf5, 0xb0
2018-11-08 21:24:11.235 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2018-11-08 21:24:11.235 Info, Node008, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x08, 0x0a, 0x98, 0x80, 0xf0, 0x9a, 0x41, 0xc4, 0x0b, 0x8f, 0xf5, 0xb0, 0x05, 0x01, 0xcd:
2018-11-08 21:24:11.243 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.243 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.266 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2018-11-08 21:24:11.266 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-08 21:24:11.266 Info, Node008, Request RTT 125 Average Request RTT 91
2018-11-08 21:24:11.288 Detail, Node008, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x08, 0x17, 0x98, 0x81, 0x6d, 0x04, 0xab, 0xc1, 0xe1, 0x82, 0xf7, 0x17, 0xeb, 0x08, 0x2f, 0x22, 0xf0, 0x17, 0x65, 0xf4, 0xdb, 0xc4, 0x79, 0xbc, 0x22, 0x00
2018-11-08 21:24:11.288 Info, Raw: 0x98, 0x81, 0x6d, 0x04, 0xab, 0xc1, 0xe1, 0x82, 0xf7, 0x17, 0xeb, 0x08, 0x2f, 0x22, 0xf0, 0x17, 0x65, 0xf4, 0xdb, 0xc4, 0x79, 0xbc, 0x22, 0x00
2018-11-08 21:24:11.288 Detail, Node008, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2018-11-08 21:24:11.288 Info, Node008, Response RTT 147 Average Response RTT 120
2018-11-08 21:24:11.288 Info, Node008, Received SwitchBinary report from node 8: level=On
2018-11-08 21:24:11.288 Detail, Node008, Initial read of value
2018-11-08 21:24:11.288 Detail, Node008, Expected reply and command class was received
2018-11-08 21:24:11.289 Detail, Node008, Message transaction complete
2018-11-08 21:24:11.289 Detail, Node008, Removing current message
2018-11-08 21:24:11.289 Detail, Node008, Notification: ValueChanged
2018-11-08 21:24:11.289 Info, Node008, Sending (Send) message (Callback ID=0x5b, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x31, 0x04, 0x04, 0x25, 0x5b, 0xa2
2018-11-08 21:24:11.297 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.297 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.319 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x5b, 0x00, 0x00, 0x03, 0xb3
2018-11-08 21:24:11.319 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x5b received (expected 0x5b)
2018-11-08 21:24:11.319 Info, Node008, Request RTT 29 Average Request RTT 60
2018-11-08 21:24:11.319 Detail, Expected callbackId was received
2018-11-08 21:24:11.333 Detail, Node008, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x08, 0x06, 0x31, 0x05, 0x04, 0x22, 0x04, 0x4c, 0xa3
2018-11-08 21:24:11.333 Info, Node008, Response RTT 44 Average Response RTT 82
2018-11-08 21:24:11.333 Info, Node008, Received SensorMultiLevel report from node 8, instance 1, Power: value=110.0W
2018-11-08 21:24:11.333 Detail, Node008, Initial read of value
2018-11-08 21:24:11.333 Detail, Node008, Expected reply and command class was received
2018-11-08 21:24:11.333 Detail, Node008, Message transaction complete
2018-11-08 21:24:11.333 Detail, Node008, Removing current message
2018-11-08 21:24:11.333 Detail, Node008, Notification: ValueChanged
2018-11-08 21:24:11.334 Detail,
2018-11-08 21:24:11.334 Info, Node008, Sending (Send) message (Callback ID=0x5c, Expected Reply=0x04) - MeterCmd_Get (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x32, 0x01, 0x00, 0x25, 0x5c, 0xa7
2018-11-08 21:24:11.342 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.342 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.363 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x5c, 0x00, 0x00, 0x03, 0xb4
2018-11-08 21:24:11.363 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x5c received (expected 0x5c)
2018-11-08 21:24:11.364 Info, Node008, Request RTT 29 Average Request RTT 44
2018-11-08 21:24:11.364 Detail, Expected callbackId was received
2018-11-08 21:24:11.379 Detail, Node008, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x08, 0x0a, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x02, 0xc0, 0x00, 0x00, 0x7e
2018-11-08 21:24:11.379 Info, Node008, Response RTT 45 Average Response RTT 63
2018-11-08 21:24:11.379 Detail, Node008, Initial read of value
2018-11-08 21:24:11.379 Info, Node008, Received Meter report from node 8: Energy=7.04kWh
2018-11-08 21:24:11.380 Detail, Node008, Initial read of value
2018-11-08 21:24:11.380 Detail, Node008, Expected reply and command class was received
2018-11-08 21:24:11.380 Detail, Node008, Message transaction complete
2018-11-08 21:24:11.380 Detail, Node008, Removing current message
2018-11-08 21:24:11.380 Detail, Node008, Notification: ValueChanged
2018-11-08 21:24:11.380 Info, Node008, Sending (Send) message (Callback ID=0x5d, Expected Reply=0x04) - MeterCmd_Get (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x32, 0x01, 0x10, 0x25, 0x5d, 0xb6
2018-11-08 21:24:11.388 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.388 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.410 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x5d, 0x00, 0x00, 0x03, 0xb5
2018-11-08 21:24:11.410 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x5d received (expected 0x5d)
2018-11-08 21:24:11.410 Info, Node008, Request RTT 29 Average Request RTT 36
2018-11-08 21:24:11.410 Detail, Expected callbackId was received
2018-11-08 21:24:11.426 Detail, Node008, Received: 0x01, 0x0e, 0x00, 0x04, 0x00, 0x08, 0x08, 0x32, 0x02, 0x21, 0x32, 0x04, 0x4c, 0x00, 0x00, 0x9e
2018-11-08 21:24:11.426 Info, Node008, Response RTT 46 Average Response RTT 54
2018-11-08 21:24:11.426 Detail, Node008, Refreshed Value: old value=false, new value=false, type=bool
2018-11-08 21:24:11.426 Detail, Node008, Changes to this value are not verified
2018-11-08 21:24:11.426 Info, Node008, Received Meter report from node 8: Power=110.0W
2018-11-08 21:24:11.426 Detail, Node008, Initial read of value
2018-11-08 21:24:11.426 Detail, Node008, Expected reply and command class was received
2018-11-08 21:24:11.426 Detail, Node008, Message transaction complete
2018-11-08 21:24:11.427 Detail,
2018-11-08 21:24:11.427 Detail, Node008, Removing current message
2018-11-08 21:24:11.427 Detail, Node008, Notification: ValueChanged
2018-11-08 21:24:11.427 Info, Node008, Sending (Send) message (Callback ID=0x5e, Expected Reply=0x04) - AlarmCmd_Get (Node=8): 0x01, 0x0c, 0x00, 0x13, 0x08, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x5e, 0xea
2018-11-08 21:24:11.435 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-08 21:24:11.435 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-08 21:24:11.457 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x5e, 0x00, 0x00, 0x03, 0xb6
2018-11-08 21:24:11.457 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x5e received (expected 0x5e)
2018-11-08 21:24:11.457 Info, Node008, Request RTT 30 Average Request RTT 33
2018-11-08 21:24:11.457 Detail, Expected callbackId was received
2018-11-08 21:24:11.473 Detail, Node008, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x08, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x08, 0xfe, 0x00, 0x88
2018-11-08 21:24:11.473 Info, Node008, Response RTT 45 Average Response RTT 49
2018-11-08 21:24:11.473 Info, Node008, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Power Management event:254, status=255
2018-11-08 21:24:11.473 Detail, Node008, Initial read of value
2018-11-08 21:24:11.473 Detail, Node008, Expected reply and command class was received
2018-11-08 21:24:11.473 Detail, Node008, Message transaction complete
2018-11-08 21:24:11.473 Detail, Node008, Removing current message
2018-11-08 21:24:11.473 Detail, Node008, Notification: ValueChanged
2018-11-08 21:24:11.473 Detail, Node007, Query Stage Complete (Dynamic)
2018-11-08 21:24:11.473 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2018-11-08 21:24:11.473 Detail, Node007, QueryStage_Configuration
2018-11-08 21:24:11.473 Detail, Node007, QueryStage_Complete
2018-11-08 21:24:11.473 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-11-08 21:24:11.473 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=0
2018-11-08 21:24:11.473 Detail, Node007, Notification: NodeQueriesComplete
2018-11-08 21:24:11.474 Detail, Node008, Query Stage Complete (Dynamic)
2018-11-08 21:24:11.474 Detail, Node008, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2018-11-08 21:24:11.474 Detail, Node008, QueryStage_Configuration
2018-11-08 21:24:11.474 Detail, Node008, QueryStage_Complete
2018-11-08 21:24:11.474 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-11-08 21:24:11.474 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2018-11-08 21:24:11.474 Info, Node query processing complete except for sleeping nodes.
2018-11-08 21:24:11.474 Detail, Node008, Notification: NodeQueriesComplete
2018-11-08 21:24:11.474 Detail, contrlr, Notification: AwakeNodesQueried
2018-11-08 21:24:44.414 Detail, Node019, AdvanceQueries queryPending=1 queryRetries=0 queryStage=CacheLoad live=1
2018-11-08 21:24:54.473 Info, Node019, Value::Set - COMMAND_CLASS_CONFIGURATION - BASIC ON frame value - 11 - 1 - 255
2018-11-08 21:24:54.473 Info, Node019, Configuration::Set - Parameter=11, Value=255 Size=1
2018-11-08 21:24:54.473 Detail, Node019, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_CONFIGURATION
2018-11-08 21:24:54.473 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Set (Node=19): 0x01, 0x0c, 0x00, 0x13, 0x13, 0x05, 0x70, 0x04, 0x0b, 0x01, 0xff, 0x25, 0x60, 0x32
2018-11-08 21:24:54.473 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Get (Node=19): 0x01, 0x0a,
Does someone have an idea of the cause? What are possible solutions?
Thx for the collaboration.
