Change ThermoStat value on FloorPlan
luberth
Domoticz version: 4.9700
Post by luberth »
Hello All,
is it possible to set/change the temperature setting of dummy thermostat setting from the floorplan
in the python thermostat you can change mode and control on floorplans webpage
but temp setting i do not get
http://test:[email protected]:8080/#/Floorplans
ok as user test it is not possible
but as admin i also can not change temp setting on floorplan
do i miss somethig?
greet luberth
wewa
Re: Change ThermoStat value on FloorPlan
Post by wewa »
Hello luberth,
this issue is also discussed in this thread https://www.domoticz.com/forum/viewtopi ... 34&t=13828 but it seems that there is no solution so far :( ...
