Python script for full rgb + brightness control of easyESP neopixel
stephenmhall
Post by stephenmhall »
I was trying to control an easyESP neopixel from an RGB switch but the best I could do was switch on a pre defined colour and brightness by sending the Neopixel command from the on/off action command as below.
http://espeasyIPaddress/control?cmd=NeoPixelAll,255,255,0
http://espeasyIP/control?cmd=NeoPixelAll
I tried some blocky code but could not find out how to get the current colour and brightness levels.
So after some googling I wrote a python script that is run on the on/off command. And it works even better than I hoped, as whenever you make a change on the colour wheel or brightness it also runs the script, it must count as an "on" command on a change.
Here is my script. It is saved in domoticz/scripts/python. Make sure you chmod +x the file so it runs. my file is called owl2.py as it is a nightlight that sits in a printed owl body. The script queries Domoticz to get the current state of the switch by ID (97 here). Parses out the json to get the colours, brightness and the on/off state. Then builds a url string to change colours on the eastESP device. I also have a HA bridge running so this will all work with Alexa.
#!/usr/bin/env python
import requests
import ast
ID = '97'
domo_url = "http://<username:password>@domoticzIP:port/json.htm?type=devices&rid={}".format(ID)
owl_control_url = 'http://easyESPIPaddress/control?cmd=NeoPixelAll,{},{},{}'
def app():
    data = requests.get(url=domo_url)
    colour_data = ast.literal_eval(data.json()['result'][0]['Color'])
    level_data = data.json()['result'][0]['Level']
    state = data.json()['result'][0]['Data']
    red = int(colour_data["r"])
    green = int(colour_data["g"])
    blue = int(colour_data["b"])
    level = int(level_data)
    redl = int((red/100) * level)
    greenl = int((green/100) * level)
    bluel = int((blue/100) * level)
    if state == 'Off':
        redl = 0
        greenl = 0
        bluel = 0
    #send to light
    _i = requests.get(url=owl_control_url.format(redl,bluel,greenl))
if __name__ == "__main__":
    app()
The onAction command is
script:///volume1/@appstore/domoticz/scripts/python/owl2.py
stephenmhall
Re: Python script for full rgb + brightness control of easyESP neopixel
Still playing with this, have updated it to accept sys args so you only need one script.
import sys
import getopt
import requests
import ast
def app(argv):
    ID = ''
    IP = ''
    try:
        opts, args = getopt.getopt(argv, "hi:e:", ["ID=", "IP="])
    except getopt.GetoptError:
        print("night_light.py -i <Domoticz IDX> -e <easyESP IP last octet>")
        sys.exit(2)
    for opt, arg in opts:
        if opt == '-h':
            sys.exit()
        elif opt in ("-i", "--id"):
            ID = arg
        elif opt in ("-e", "eIP"):
            IP = arg
    try:
        if state == 'Off':
            redl = 0
            greenl = 0
            bluel = 0
        #send to light
        owl_control_url = 'http://easyESPipaddress.{}/control?cmd=NeoPixelAll,{},{},{}'.format(IP, redl, bluel, greenl)
        _i = requests.get(url=owl_control_url)
    except Exception as err:
        print(err)
        sys.exit()
    app(sys.argv[1:])
run the script with IDX and final octet of the easyESP ip address
script:///volume1/@appstore/domoticz/scripts/python/night_light.py -i 97 -e 124
vrega
Post by vrega »
Hi,i've tried your script.
In the log i've this error:
Error: Error executing script command (/opt/domoticz/scripts/python/ledstrip.py). returned: 256
If i try to launch the script from cli using
python ledstrip.py -i 97 -e 233
it gives me:
File "ledstrip.py", line 5, in <module>
import requests
ImportError: No module named requests
Can you help me to find why it gives me this message?
