Trying to... timed change setpoint with Blockly
Patricen
Domoticz version: Beta rel
Post by Patricen »
Hi!
As I'm really not a programming guy, Blockly puzzles are simple enough for me, but...
I do have a Popp thermostat, seen as a setpoint from Domoticz, it is programmed with a timer within Domoticz.
I'd like to temporarily give a certain setpoint for a certain time that would override timer schedule, and as soon as the desired time is over, the setpoint of the timer schedule is used.
Unfortunately Blockly doesn't allow "Set setpoint to 22°C for X minutes" nor a countdown timer.
Does anybody have an idea?
Patrice
125db
Re: Trying to... timed change setpoint with Blockly
Post by 125db »
Heyo, welcome to the Blockly world!
You could try creating a variable, ex. "setpoint_timer" and do something like this:
If [setpoint_timer] = 0 and [your action/trigger]
Set setpoint at 22C
Set [your action/trigger] = off (if it's a switch)
Set [setpoint_timer] = 1 after XX minutes
Else if [setpoint_timer] = 1
Set setpoint off
Set [setpoint_timer] = 0
Let me know if it works for you
Patricen
Post by Patricen »
It is unfortunately not so simple. I'm using timer plans and it does not seems to be working
MarnixO
Domoticz version: V4.10199
Post by MarnixO »
i have also popp TRV's and il use a blockly http action to set my thermostat setpoint
http://192.168.1.32:8080/json.htm?type= ... &used=true
This is ilustrated by the wiki , look for evohome updating a zone setpoint
