I've set up a power pulse sensor usin the sketch n the build section of mysensors which feeds through to Domoticz.
I'm fairly sure the sketch transmits from the sensor to Domoticz every 20 seconds (20000ms).
Domotics only seems to updates the plot for Watts every 5 minutes and total energy every hour. Consequently, it seems that Blocky only reviews the IF / Do (based on Watts) at that frequency. I'd prefer to have domotics taking actions more frequently (ie every 20 seconds).
Can the update frequency be changed in a setting anywhere?
Update frequency?
- waaren
Re: Update frequency?
My test blockly based on P1 device triggers every 10 seconds.
The 5 minute interval you are referring to is for writing the value from the deviceStatus to one of the calendar tables to enable graphs and reports. So if your blockly is looking at a device that is updated every 20 seconds it should trigger every 20 seconds.
StKilda
Hmm. ok thanks. Not sure it is then. I'm new to writing and understanding the sketches. I'm wondering then if the sketch - which seems to have a minimum and maximum frequency of sending data to the gw - might be decreasing the update frequency when power usage is low?
For my purpose I want a 20 second update - as its exactly when power usage is low that I want to know about it. Here's the code: Can you spot anything that might reduce update rate?
The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <[email protected]>
* Copyright (C) 2013-2018 Sensnology AB
* Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* DESCRIPTION
* This sketch provides an example how to implement a LM393 PCB
* Use this sensor to measure kWh and Watt of your house meter
* You need to set the correct pulsefactor of your meter (blinks per kWh).
* The sensor starts by fetching current kWh value from gateway.
* Reports both kWh and Watt back to gateway.
* Unfortunately millis() won't increment when the Arduino is in
* sleepmode. So we cannot make this sensor sleep if we also want
* to calculate/report watt value.
* http://www.mysensors.org/build/pulse_power
// Enable debug prints
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_RF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
#include <MySensors.h>
#define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your light sensor. (Only 2 and 3 generates interrupt!)
#define PULSE_FACTOR 1000 // Number of blinks per of your meter
#define SLEEP_MODE false // Watt value can only be reported when sleep mode is false.
#define MAX_WATT 10000 // Max watt value to report. This filters outliers.
#define CHILD_ID 1 // Id of the sensor child
uint32_t SEND_FREQUENCY =
20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
bool pcReceived = false;
volatile uint32_t pulseCount = 0;
volatile uint32_t lastBlink = 0;
volatile uint32_t watt = 0;
uint32_t oldPulseCount = 0;
uint32_t oldWatt = 0;
double oldkWh;
uint32_t lastSend;
MyMessage wattMsg(CHILD_ID,V_WATT);
MyMessage kWhMsg(CHILD_ID,V_KWH);
MyMessage pcMsg(CHILD_ID,V_VAR1);
void setup()
// Fetch last known pulse count value from gw
request(CHILD_ID, V_VAR1);
// Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
// If no pullup is used, the reported usage will be too high because of the floating pin
pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
lastSend=millis();
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo("Energy Meter", "1.0");
// Register this device as power sensor
present(CHILD_ID, S_POWER);
void loop()
uint32_t now = millis();
// Only send values at a maximum frequency or woken up from sleep
bool sendTime = now - lastSend > SEND_FREQUENCY;
if (pcReceived && (SLEEP_MODE || sendTime)) {
// New watt value has been calculated
if (!SLEEP_MODE && watt != oldWatt) {
// Check that we don't get unreasonable large watt value.
// could happen when long wraps or false interrupt triggered
if (watt<((uint32_t)MAX_WATT)) {
send(wattMsg.set(watt)); // Send watt value to gw
Serial.print("Watt:");
Serial.println(watt);
oldWatt = watt;
// Pulse count value has changed
if (pulseCount != oldPulseCount) {
send(pcMsg.set(pulseCount)); // Send pulse count value to gw
double kWh = ((double)pulseCount/((double)PULSE_FACTOR));
oldPulseCount = pulseCount;
if (kWh != oldkWh) {
send(kWhMsg.set(kWh, 4)); // Send kWh value to gw
oldkWh = kWh;
lastSend = now;
} else if (sendTime && !pcReceived) {
// No pulse count value received. Try requesting it again
lastSend=now;
if (SLEEP_MODE) {
sleep(SEND_FREQUENCY);
void receive(const MyMessage &message)
if (message.type==V_VAR1) {
pulseCount = oldPulseCount = message.getLong();
Serial.print("Received last pulse count value from gw:");
Serial.println(pulseCount);
pcReceived = true;
void onPulse()
if (!SLEEP_MODE) {
uint32_t newBlink = micros();
uint32_t interval = newBlink-lastBlink;
if (interval<10000L) { // Sometimes we get interrupt on RISING
return;
watt = (3600000000.0 /interval) / ppwh;
lastBlink = newBlink;
pulseCount++;
Datasheets- waaren
Sorry I don't have any knowledge in that area.StKilda wrote: Sunday 28 October 2018 15:19 For my purpose I want a 20 second update - as its exactly when power usage is low that I want to know about it. Here's the code: Can you spot anything that might reduce update rate?
If you look at the domoticz gui (devices tab) and do regular page reloads, what frequency do you observe for the device you are updating with this sketch ?
