YAP (yet another pinger)
Yet another pinger solution.
new version 20191031 !
Have Fun !
  --[[ pinger: requires - dzVents >= 2.4,
                       - find Operating System command available and executable by domoticz user
                       - ping Operating System command available and executable by domoticz user
                       - nmap Operating System command available and executable by domoticz user (only when also scanning TCP ports)
    This script checks if systems are reacting to a ping command or if a tcp port is responding with "open" to a nmap command
    The systems to be checked are in the table sites2Check.
    when no port(s) is/are in that the table, a standard ping is executed at the OS level and the returnCode is evaluated
    The default settings for notifications are entered in the table "defaults".
    These defaults can be overruled by entering them in the table sites2Check (see the example)
    When no message is entered in the table sites2Check, the composed Operating System command is used as message
    NB. silentTime "never" or "24:00"  means allways notify. (never silent = )
    The script checks the modification dates of the script and its companion datafile
    to ensure a refresh or initialization of __data_scriptname.lua after any
    change to the script.
    Note: After a refresh the number of fails and the isMessageSend flag are preserved.
    History
    20181026 Start coding
    20181027 First version active and shared on forum
    20181109 Bugfixes
    20181109 Script will recognize requirement to refresh datafile
    20181109 Add option to check ports (with nmap)
    20181109 Add option to suppress notifications / Email after first message of the day
    20181109 Add option for non standard message
    20191031 Fixed bug ( t.consecutiveFailCount not initialized)
    on      =   {   timer   = { "every 5 minutes"},
                   devices  = { "Pinger"},                      -- Used for test / development. Can be ignored
    logging =   {   level   = domoticz.LOG_DEBUG ,              -- Change to ERROR when script is behaving as expected
                    marker  = ""},                              -- Will be set in execute = function block
    data    =   {   sites2Check   =      { initial = {}   }},   -- Iitialize empty table
 execute = function(dz,_,info)                             -- We don't use the trigger but we do need the info (for scriptName)
        local sites2Check , defaults  = {}, {}             -- Initialize empty tables
        -- **************************************************************** Your settings below this line
        defaults  = {   messageClearTime        = "05:05",    -- must be a multiple of 5 ( or change the on = { timer - {} setting
                                                              -- Once a day the sendMessage flag must be cleared; it will happen at this time
                        maxExecutionTime        = 3.0,        -- If multiple pings fail the script will run too long. This will
                                                              -- ensure the script stops after maxExecutionTime seconds
                        pingWaitTime            = 1,          -- the ping command parm -w is how long the ping should wait for an answer
                                                              -- if one second is not long enough you can set it to an higher value here
                        maxFailsBeforeMessage   = 3,          -- the message will only be send after this amount of consecutive failed pings or nmaps
                        repeatMessageAfterFails = 5,          -- number of consecutive fails before Message will be send again repeat
                        silentTime     = "23:00-07:00",       -- The time window when no messages are to be send
                        repeatMessage  = false,               -- When set to false only first message on a day will be send,
                                                              -- when true every x fails a message will be send
                        toLog          = true,                -- used in report (should we send message to log on failure)
                        toEmail        = false,               -- used in report (should we send message to Email on failure)
                        notify         = true,                -- used in report (should we send message to notification system on failure)
                        notifyPriority = dz.PRIORITY_NORMAL,
                        mailAddress    = "[email protected]",
     -- sites2Check.example      = {address = "192.168.193.1", toEmail = true, silentTime = "never" ,repeatMessage = true }
     -- sites2Check.example2     = {address = "RaspBerry1", port = { 80,8084,1111,8080 }, message = "nmap to port failed" }
    --    sites2Check.HomeWizard   = {address =  "192.168.192.61" }           -- Label, Address (dns name or IP ), defaultOverrides, port(s)
    --    sites2Check.PI2          = {address = "PI-2" }
        sites2Check.Google       = {address = "google-public-dns-a.google.com"}
    --    sites2Check.synology     = {address = "LM46" }
        sites2Check.router       = {    address                 = "192.168.20.1",
                                        toEmail                 = true,                              -- Overrule defaults
                                        silentTime              = "01:00-06:00",                     -- Overrule defaults
                                        notifyPriority          = dz.PRIORITY_HIGH,                  -- Overrule defaults
                                        message                 = "Ping to router failed"    -- Overrule defaults
        sites2Check.test         = {    address                 = "192.168.20.32",         -- address (mandatory) , port(s) (optional)
         --                               port                    = { 82 },            -- this will cause the use of nmap
                                        maxFailsBeforeMessage   = 5,                           -- Overrule defaults
                                        silentTime              = "00:00-07:00",               -- Overrule defaults
        myNotificationTable     =  {
                                     -- table with one or more notification system.
                                     -- uncomment the notification systems that you want to be used
                                     -- Can be one or more of
                                     -- dz.NSS_GOOGLE_CLOUD_MESSAGING,
                                     dz.NSS_PUSHOVER,
                                     -- dz.NSS_HTTP,
                                     -- dz.NSS_KODI,
                                     -- dz.NSS_LOGITECH_MEDIASERVER,
                                     -- dz.NSS_NMA,
                                     -- dz.NSS_PROWL,
                                     -- dz.NSS_PUSHALOT,
                                     -- dz.NSS_PUSHBULLET,
                                     -- dz.NSS_PUSHOVER,
                                     -- dz.NSS_PUSHSAFER,
  -- **************************************************************** No changes required below this
        _G.logMarker                    = info.scriptName     -- sets the logmarker for dz.log
        local messageSendClearRequired  = dz.time.matchesRule("at " .. defaults.messageClearTime)
        local function logWrite(str,level)
            dz.log(str,level or dz.LOG_DEBUG)
        -- initialise persistent data
        local function initSites2Check()
            dz.data.sites2Check.defaults = defaults
            for system,_ in pairs(sites2Check) do                                   -- We only need the system names or IP, ports, consecutive failCount and flag isMessageSend
                dz.data.sites2Check[system] = dz.data.sites2Check[system] or {}
                if sites2Check[system].port then
                    for i,portNumber in ipairs(sites2Check[system].port) do
                        dz.data.sites2Check[system][portNumber] = {}
                        dz.data.sites2Check[system][portNumber].consecutiveFailCount    =
                        dz.data.sites2Check[system][portNumber].consecutiveFailCount or 0
                        dz.data.sites2Check[system][portNumber].isMessageSend             =
                        dz.data.sites2Check[system][portNumber].isMessageSend or false
                    dz.data.sites2Check[system].consecutiveFailCount    =
                    dz.data.sites2Check[system].consecutiveFailCount or 0
                    dz.data.sites2Check[system].isMessageSend             =
                    dz.data.sites2Check[system].isMessageSend or false
        --Report to log and/or Email and/or noticication system
        local function report(systemName,returnCode,commandUsed,messageCount,isMessageSend)
            local system        = sites2Check[systemName]
            logWrite("default repeatMessage in report: " .. tostring(defaults.repeatMessage))
            logWrite(systemName .. " repeatMessage in report: " .. tostring(system.repeatMessage ))
            local repeatMessage             = system.repeatMessage           or defaults.repeatMessage
            local repeatMessageAfterFails   = system.repeatMessageAfterFails or defaults.repeatMessageAfterFails
            local priority                  = tonumber(system.notifyPriority or defaults.notifyPriority)
            local defaults                  = dz.data.sites2Check.defaults
            local message                   = system.message or
                                                "osCommand ".. commandUsed .. " failed for " .. systemName .. ": ReturnCode ==>>: " .. returnCode
            local function doReport(str)
                local returnValue = false
                local silent  = dz.time.matchesRule("at " .. (system.silentTime or defaults.silentTime))
                local toLog   = system.toLog            or defaults.toLog
                local toEmail = ( system.toEmail        or defaults.toEmail ) and not silent
                local mailTo  = system.mailAddress      or defaults.mailAddress
                local notify  = ( system.notify         or defaults.notify ) and not silent
                if toLog then logWrite(str,dz.LOG_FORCE) end
                if toEmail then
                    dz.email(info.scriptName,str,mailTo)
                    returnValue = true
                if notify then
                    dz.notify(info.scriptName, str, priority, dz.SOUND_INTERMISSION,"",   myNotificationTable )
                    returnValue = true
                return returnValue
            local messageCountFence = math.min(defaults.maxFailsBeforeMessage,system.maxFailsBeforeMessage or 99)
            if messageCount == messageCountFence then
                return doReport("initial: ".. message)
            elseif messageCount % repeatMessageAfterFails == 0 and repeatMessage and isMessageSend then
                return doReport("repeated: ".. message)
            elseif messageCount > messageCountFence  and messageCount % repeatMessageAfterFails == 0 and repeatMessage and not isMessageSend then
                return doReport("initial but delayed: " .. message)
            elseif isMessageSend then
               return true
            elseif messageCount < messageCountFence then
               return false
        local function osCommand(commandString)
            local fileHandle     = assert(io.popen(commandString, 'r'))
            local commandOutput  = assert(fileHandle:read('*a'))
            local returnTable    = {fileHandle:close()}
            return commandOutput,returnTable[3]                     -- returnTable[3] contains returnCode
        local function evalReturnCode(t,returnCode,systemName,cmdString)
            if returnCode ~= 0 then
                t.consecutiveFailCount = ( t.consecutiveFailCount or 0 ) + 1
                t.isMessageSend = report(systemName,returnCode,cmdString,t.consecutiveFailCount,t.isMessageSend)
                t.consecutiveFailCount = 0
                t.isMessageSend = false
        local function fileExists(filename)
            local file = io.open(filename, "r")
            if file ~= nil then io.close(file) return true end
            return false
        local function getPersistentDataFileName()
            return globalvariables['script_path'] .. "data/__data_" .. info.scriptName .. ".lua"
        local function invalidPersistentDatafile()
            local dataFile  = getPersistentDataFileName()
            if not fileExists(dataFile) then
                logWrite("initSites2Check() must be called. (file does not exist)" )
                return true
            if fileExists(_G.generatedScriptsFolderPath ..  info.scriptName .. ".lua") then
                script = _G.generatedScriptsFolderPath ..  info.scriptName .. ".lua"
                script = globalvariables['script_path'] .. "scripts/" .. info.scriptName .. ".lua"
            if (select(1,osCommand("find " .. script .." -newer " .. dataFile))):find(script) then
                logWrite("initSites2Check() must be called. (script newer than datafile)" )
                return true
            return false
        local function clearMessageSend()
            logWrite("isMessageSend will be cleared")
            for systemName,attributes in pairs(sites2Check) do
                if attributes.address ~= nil then         -- defaults does not have an address
                    if attributes.port ~= nil then  -- Ports defined so we need to call nmap (ping cannot do this)
                        for i=1,#attributes.port do
                            attributes.port.isMessageSend = false
                            dz.data.sites2Check[systemName].port.isMessageSend = false
                        attributes.isMessageSend = false
                        dz.data.sites2Check[systemName].isMessageSend = false
            return true
        local function isExecutionTimeTooLong(startedAt)
            return (os.clock() - startedAt) > defaults.maxExecutionTime
        -- main
        local startedAt  = os.clock()
        if messageSendClearRequired then clearMessageSend() end
        if invalidPersistentDatafile() then initSites2Check() end
                local cmdString
                local message
                local system        = dz.data.sites2Check[systemName]
                if isExecutionTimeTooLong(startedAt) then logWrite("break main") break end
                        logWrite("ports defined; Checking " .. attributes.address .. " for port " .. attributes.port[i])
                        cmdString = "nmap " .. attributes.address .. " -p " .. attributes.port[i] .. " | grep open"
                        evalReturnCode(system[attributes.port[i]],select(2,osCommand(cmdString)),systemName,cmdString)
                        if isExecutionTimeTooLong(startedAt) then break end
                else -- Simple ping command
                    local pingWaitTime = attributes.pingWaitTime or defaults.pingWaitTime
                    logWrite("Checking " .. attributes.address )
                    cmdString = "ping -c1 -w " .. pingWaitTime .. " >/dev/null " .. attributes.address
                    evalReturnCode(system,select(2,osCommand(cmdString)),systemName,cmdString)
pavelbor
Domoticz version: LastBeta
Re: YAP (yet another pinger)
Post by pavelbor »
thanx for example of the script. But when started, and detected that some device is offline, script start to send notification every 5 minutes until device becomes online. It will produce lot of spamming notification.
Would be nice to set some variable (for each device), like notification_sent_deviceNAME (initial = 0).
When script detect that device is offline, variable notification_sent_deviceNAME becomes 1, first notification will be sended, and then with every cycle variable increased by +1.
Next notification may be sended in next 24hr, for example - notification_sent_deviceNAME ==288, and at that time variable could be reseted back to 0.
pavelbor wrote: Thursday 08 November 2018 10:19 Hello,
New version is being tested as we speak.
Version will include your proposed improvement and also possibility to check ports (using nmap)
I will probably post the update tomorrow
New version posted here
megamarco83
Post by megamarco83 »
hi to all, i'm using this script but i find one issue related maybe to my configuration:
i have some devices that take some time to respond, maybe because they are on wifi and the signal is not so strong....so i receive false massage, i mean that i receve notification that device is not conttected, but in reality that devices is connected. i try to use this parameter inside the script:
pingWaitTime = 2,
if i understand well the code, it use inside ping command the parametr -w2
but in this case, if from windows system i open cmd shell and i try to use:
ping 192.168.0.200 -w2
i receive some errors
if i use:
ping 192.168.0.200
(whitout parameter -w2)
i receive the response without errors.
here one picture:
https://ibb.co/G9wXGck
in your opinion could be that one the issue related to false message coming from telegram ?
thanks to all :-)
megamarco83 wrote: Thursday 09 January 2020 19:30 I try to use this parameter inside the script:
pingWaitTime = 2,
Funny stuff going on here. Linux reacts different to these parameters compared to Windows.
On linux all below ping parameter variants work as expected.
waaren@NUC: 192.168.192.115:/usr/local/domotica:$ping -w2 pi-1
PING PI-1 (192.168.192.51) 56(84) bytes of data.
64 bytes from PI-1 (192.168.192.51): icmp_seq=1 ttl=64 time=3.45 ms
64 bytes from PI-1 (192.168.192.51): icmp_seq=2 ttl=64 time=5.29 ms
--- PI-1 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 3ms
rtt min/avg/max/mdev = 3.450/4.371/5.293/0.923 ms
waaren@NUC: 192.168.192.115:/usr/local/domotica:$ping -w 2 pi-1
64 bytes from PI-1 (192.168.192.51): icmp_seq=1 ttl=64 time=3.74 ms
64 bytes from PI-1 (192.168.192.51): icmp_seq=2 ttl=64 time=4.72 ms
2 packets transmitted, 2 received, 0% packet loss, time 2ms
rtt min/avg/max/mdev = 3.739/4.228/4.717/0.489 ms
waaren@NUC: 192.168.192.115:/usr/local/domotica:$ping -c 1 -w2 pi-1
64 bytes from PI-1 (192.168.192.51): icmp_seq=1 ttl=64 time=2.60 ms
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 2.596/2.596/2.596/0.000 ms
root@NUC: 192.168.192.115:/usr/local/domotica:#ping -c 1 -w 2 pi-1
64 bytes from PI-1 (192.168.192.51): icmp_seq=1 ttl=64 time=3.39 ms
rtt min/avg/max/mdev = 3.390/3.390/3.390/0.000 ms
root@NUC: 192.168.192.115:/usr/local/domotica:#ping -w 2 -c 1  pi-1
64 bytes from PI-1 (192.168.192.51): icmp_seq=1 ttl=64 time=11.0 ms
rtt min/avg/max/mdev = 11.005/11.005/11.005/0.000 ms
Windows does NOT like some of these variants
Microsoft Windows [Version 10.0.19041.1]
(c) 2019 Microsoft Corporation.
C:\WINDOWS\system32>ping -c1 -w2 192.168.192.66
Pinging 192.168.192.66 with 32 bytes of data:
Reply from 192.168.192.66: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.192.66:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\WINDOWS\system32>ping -w2 192.168.192.66
IP address must be specified.
C:\WINDOWS\system32>ping -w 2 192.168.192.66
    Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
C:\WINDOWS\system32>ping -c1 -w 2  192.168.192.66
Bad parameter 192.168.192.66.
C:\WINDOWS\system32>ping -w2  -c1 192.168.192.66
PING: transmit failed. General failure.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
So I don't see a relation between the problem you see with the Ping command on Windows and your extra Telegram messages.
megamarco83
waaren wrote: Thursday 09 January 2020 22:27
Hi Waaren, yes, you are right, i tested the ping command on raspberry and it works in a different way compared to windows
pi@raspberrypi:~ $ ping -c2 -w2 192.168.0.200
PING 192.168.0.200 (192.168.0.200) 56(84) bytes of data.
64 bytes from 192.168.0.200: icmp_seq=1 ttl=255 time=9.80 ms
64 bytes from 192.168.0.200: icmp_seq=2 ttl=255 time=94.3 ms
--- 192.168.0.200 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 9.807/52.078/94.350/42.272 ms
pi@raspberrypi:~ $
but my issue is related to receving false notification related to a device that for the script is disconnected but in realty it isn't.
just an example of some minutes ago.
my device that has ip 192.168.0.200
here in this picture you can see that the device is active since more that 6 days....
here you can see that i receive a message this evening comin from telegram, trigered by the script, about a disconnection of my devices.
these are my parameters inside the script:
                        maxExecutionTime        = 3.0,        -- If multiple pings fail the script will run too long this will
                        pingWaitTime            = 2,          -- the ping command parm -w is how log the ping should wait for an answer
                        silentTime              = "23:00-07:00",  -- The time window when no messages are to be send.
        --NB. silentTime "never" or "24:00"  means allways notify. (never silent = )
megamarco83 wrote: Thursday 09 January 2020 23:27 but my issue is related to receving false notification related to a device that for the script is disconnected but in realty it isn't.
The ping script does not test if a system is active or not. It tests if it reacts to ping within the set time. If it does not react within that time, the script will give you a message so you can investigate what is causing this.
A number of issues can lead to a ping not being successful within a given time.
The system could be very busy or heavy traffic on the network or a switch problem or a router restart and I am sure you can think of a couple of other reasons. But that's why the script sends the message to help you by giving an early warning so you can investigate and try to solve it before it get serious.
If the ping method used in this script to check this particular connection to the system is not giving the result you can work with then maybe you can use another method to check if the system is still working as designed.
Because of the design of domoticz event system it is not advisable to extend the time ping waits for a response to be much longer as you will block the complete event-system for the time it waits for a response.
Alongside this ping script I use monit as my main tool to check critical systems, tools, connections and backups. It could be wort-while for you to see if it could be of any use in your setup.
megamarco83
hi, thanks for reply.
i use this script to ask a responde to my esp8266 devices. it's very usefull to investigate if devices are off line.
sometime happen that an esp8266 go off line, and i need to reboot manually the esp, simply remove its power and then power on again.
i notice that on two devices that are positioned quite far from the router and in a postition difficult to reach also manually, you can see the signal Db that is -91db, sometimes i receive from script messges that this device is disconnect, but in realty it is still on, maybe during the ping from script, the device react slowly so it send the message.
what do you think?
maybe i can solve just increasing the ping time?
if i understand correct is the parameter -w that in the script:
pingWaitTime = 2,
maybe i can increase a bit the value?
do you have a suggestion for it?
related to "monit", i do not know what is it and how it is working :-)
i will try to search on google :)
megamarco83 wrote: Friday 10 January 2020 11:04 if i understand correct is the parameter -w that in the script: pingWaitTime = 2, maybe i can increase a bit the value?
Yes you can. Don't do it by changing the default but change it only for systems where you need it. (in the sites2Check)
You also might need to increase the overall maxExecutionTime (in the defaults)
Google is your friend :) but also on this forum you wil get > 300 hits when you use the search word monit, So it's fair to say that this forum is also a friend :D
megamarco83
waaren wrote: Friday 10 January 2020 17:08 Yes you can. Don't do it by changing the default but change it only for systems where you need it. (in the sites2Check)
you mean for example changing this:
sites2Check.Sonoff_200_VCM_mansarda = {address = "192.168.0.200" ,message = "disconnesso Sonoff_200_VCM_mansarda"}
to this:
sites2Check.Sonoff_200_VCM_mansarda = {address = "192.168.0.200" , pingWaitTime = 4, maxFailsBeforeMessage = 6 message = "disconnesso Sonoff_200_VCM_mansarda"}
that will be executed only for this devices, all other devices will keep the defaul ping, right?
thanks
