RFXtrx433XL : invalid data received - version 0
benp
Domoticz version: V4.10717
Post by benp »
I am unable to SetMode in rfxcom pannel: I return to Dashboard and all devices stay to red (disable).
Here is my log file:
 2018-10-27 10:22:16.378 Status: RFXCOM: Using serial port: /dev/ttyUSB1
2018-10-27 10:24:31.684 Error: RFXCOM: Invalid data received!....
2018-10-27 10:24:35.609 subtype = Interface Command
2018-10-27 10:24:35.609 Sequence nbr = 3
2018-10-27 10:24:35.609 set configuration of the interface
domoticz v4.9700 on raspberry Raspbian Stretch Lite
RFXtrx433XL update to the last firmware: RFXtrx433XL_ProXL1_1031.hex
Here is what I tried:
  • I tried to restart domoticz (stop/unplug/restart)
  • Hardware is enable
  • RFXtrx433XL is on /dev/ttyUSB1
  • Zigate is on /dev/ttyUSB0
  • I have version 0
  • I have read the post: RFXtrx433 Version 0
  • I have a RFXtrx433E on another raspberry and manualy copy the same config
  • RFXtrx433XL can update firmwae
  • RFXtrx433XL can detect oregon THGR810 with the RFXmngr software on W10
Thank you
Domoticz V2024.7
benp
Re: RFXtrx433XL : invalid data received - version 0
Post by benp »
Does somebody was able to successfully use the new RFXtrx433XL with domoticz stable 4.9700?
Domoticz V2024.7
antwan
Domoticz version: Latest
Post by antwan »
Yep i do, without any problem.
I only use the latest beta....
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
benp
Post by benp »
Thank you antwan.
Did you test with the stable before beta?
What beta version number is OK?
Domoticz V2024.7
antwan
Post by antwan »
Im always on the beta channel, and i never look back.
RueDesButtes
Post by RueDesButtes »
I have been able to use it on the stable version during 2 weeks,
now i have only the following:
  • 2018-11-26 17:28:55.928 Error: RFXCOM: input buffer out of sync, going to restart!....
  • 2018-11-26 18:34:38.003 Error: RFXCOM: Invalid data received!....
it seems fine on RFXmngr,
I have updated to the 1032 firmware, no difference.
Latest Beta on RPI3B+
RFX, Rflink,RM Pro, Xiaomi devices, Hue bridge, Onkyo, Harmony
RueDesButtes
i have reboot the pi,
deleted the RFXCOM hardware, created a new one (and changed the usb port) something happened at the usb management
now it is fine.
Dirk
Post by Dirk »
I had the same problem: Domoticz was not saving any changes I made to the RFXCOM-protocols and all were disabled. I removed the RFXCOM and added it with a different USB-port. Now when I click Set Mode I'll see some protocols enabled and I'm able to toggle all. Clicking on the red button Set Mode saves the changes (somewhat unintuitive; 'Save' would be better IMHO). So this solved my problem.
