I have many Sonoff POW and Medion units.
Each sends power use to the Domoticz server.
Now I would like to have a total of all the power consumption and have this displayed on the Utility page.
How can this be done?
Does anyone have an example?
Thanks in advance
Total power use
- waaren
Re: Total power use
What are the type / subtypes of the domoticz devices receiving the power usages ?tony5093 wrote: ↑Friday 26 October 2018 3:53 I have many Sonoff POW and Medion units.
Thanks in advance
Did you name these devices according to a naming convention ? (something like SonoffPowerUsage_1 .... SonoffPowerUsage_many)
Do you want to have the total displayed on a text sensor or alert sensor (or both) ?
Re: Total power use
Toy5093,
Do you have allready a solution? I'm looking for a solution to show the total power use again. This is gone with the new version of domoticz.
When you go to devices the total is there, but you can't see it within the utility page.
- michaldobrotka
Re: Total power use
This is my lua script - counting together power use from 3 Phases and updating dummy device IDX 705 (Total).
It is working, but Im geting Error message (needed some touchup) :
local DeviceName1 = "Faza1"
local DeviceName2 = "Faza2"
local DeviceName3 = "Faza3"
local ConsumptionIDX = 705 -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "Total" -- Name of the energy device that shows calculated Consumption
-- Script parameters
Energy1 = 0 -- in Watt hours
Power1 = 0 -- in Watts
Energy2 = 0 -- in Watt hours
Power2 = 0 -- in Watts
Energy3 = 0 -- in Watt hours
Power3 = 0 -- in Watts
EnergyConsumption = 0 -- in Watt hours
PowerConsumption = 0 -- in Watts
Debug = "NO" -- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
Power1, Energy1 = otherdevices_svalues[DeviceName1]:match("([^;]+);([^;]+)")
if Debug=="YES" then
print(" ----- ".. DeviceName1 .. "Power = " .. Power1 .. " W");
print(" ----- ".. DeviceName1 .. "Energy = " .. Energy1 .. " Wh");
Power2, Energy2 = otherdevices_svalues[DeviceName2]:match("([^;]+);([^;]+)")
print(" ----- ".. DeviceName2 .. "Power = " .. Power2 .. " W");
print(" ----- ".. DeviceName2 .. "Energy = " .. Energy2 .. " Wh");
Power3, Energy3 = otherdevices_svalues[DeviceName3]:match("([^;]+);([^;]+)")
print(" ----- ".. DeviceName3 .. "Power = " .. Power3 .. " W");
print(" ----- ".. DeviceName3 .. "Energy = " .. Energy3 .. " Wh");
-- Calculate consumption
PowerConsumption = Power1 + Power2 + Power3
print(" ----- PowerConsumption = " .. PowerConsumption .. " W");
EnergyConsumption = Energy1 + Energy2 + Energy3
print(" ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
-- Update comsumption device in Domoticz
if devicechanged[DeviceName1] or devicechanged[DeviceName2] or devicechanged[DeviceName3] then
update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
2018-11-19 14:43:00.344 Error: EventSystem: in celkovaspotreba: [string "-- /home/pi/domoticz/scripts/lua/script_devic..."]:65: attempt to index global 'devicechanged' (a nil value)
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
