Switching on/off fan with event
Posted: Monday 22 October 2018 10:47
by mcjackdus
Hello All,
I am running domoticz on a synology nas and added some fibaro z-wave devices with a z-wave usb.
So far everything is running fine, but
I created an event that my bathroom fan is switching on/off when the light of the bathroom is switching on/off
Now when I switch the light with the domoticz app it is working however when I use the light switch in the bathroom the fan is not switching on.
When I than turn on the fan using the app, switching off the fan works when I turn off the lights using the light switch.
I was hoping someone can help me out what could be the problem?
Thanks in advance
Jack
Re: Switching on/off fan with event
Posted: Monday 22 October 2018 11:08
by SweetPants
Please post the event(script), hard to tell now what is going on
Posted: Tuesday 23 October 2018 7:46
by mcjackdus
SweetPants wrote: Monday 22 October 2018 11:08 Please post the event(script), hard to tell now what is going on
I don't know how to insert a picture here
Posted: Tuesday 23 October 2018 8:37
by SweetPants
In "Full Editor" mode you can add an attachment to the post and insert it.
Posted: Tuesday 23 October 2018 9:04
by mcjackdus
Ah yes...thank you.
Domoticz 2.jpg (76.99 KiB) Viewed 923 times
Domoticz 1.jpg (88.35 KiB) Viewed 923 times
Posted: Tuesday 23 October 2018 10:38
by mcjackdus
SweetPants wrote: Tuesday 23 October 2018 8:37 In "Full Editor" mode you can add an attachment to the post and insert it.
Thanks...Pictures added above
Posted: Tuesday 23 October 2018 11:16
by SweetPants
I'm not familiar with Zwave, but if you switch the "Badkamer" to On/Off, you see the actual change in domoticz?
Posted: Tuesday 23 October 2018 20:57
by mcjackdus
SweetPants wrote: Tuesday 23 October 2018 11:16 I'm not familiar with Zwave, but if you switch the "Badkamer" to On/Off, you see the actual change in domoticz?
The light is switched with a dimmer so it changes from off to set level xx%.
Thats problably why off is working.
I trede switching on above a certain set level now but this is also not working
