Switching on/off fan with event
mcjackdus
Post by mcjackdus »
Hello All,
I am running domoticz on a synology nas and added some fibaro z-wave devices with a z-wave usb.
So far everything is running fine, but
I created an event that my bathroom fan is switching on/off when the light of the bathroom is switching on/off
Now when I switch the light with the domoticz app it is working however when I use the light switch in the bathroom the fan is not switching on.
When I than turn on the fan using the app, switching off the fan works when I turn off the lights using the light switch.
I was hoping someone can help me out what could be the problem?
Thanks in advance
Jack
SweetPants
Re: Switching on/off fan with event
Post by SweetPants »
Please post the event(script), hard to tell now what is going on
mcjackdus
Post by mcjackdus »
SweetPants wrote: Monday 22 October 2018 11:08 Please post the event(script), hard to tell now what is going on
I don't know how to insert a picture here
SweetPants
In "Full Editor" mode you can add an attachment to the post and insert it.
mcjackdus
Post by mcjackdus »
Ah yes...thank you.
Domoticz 2.jpg (76.99 KiB) Viewed 1165 times
Domoticz 1.jpg (88.35 KiB) Viewed 1165 times
mcjackdus
Post by mcjackdus »
SweetPants wrote: Tuesday 23 October 2018 8:37 In "Full Editor" mode you can add an attachment to the post and insert it.
Thanks...Pictures added above
SweetPants
I'm not familiar with Zwave, but if you switch the "Badkamer" to On/Off, you see the actual change in domoticz?
mcjackdus
Post by mcjackdus »
SweetPants wrote: Tuesday 23 October 2018 11:16 I'm not familiar with Zwave, but if you switch the "Badkamer" to On/Off, you see the actual change in domoticz?
The light is switched with a dimmer so it changes from off to set level xx%.
Thats problably why off is working.
I trede switching on above a certain set level now but this is also not working
