IFTTT: How to Parameterised webhooks with google assistant ?
Posted: Monday 22 October 2018 3:04
I want to tell my google assistant to change my TV input channel to HDMI1 or Netflix etc.
And i want IFTTT to send the correct command to Domoticz.
How can i make this possible?
The code below wont work because Set%20Level expects a number.
If You say "change tv input chanel to $", then Make a web request:
The lvl expects a number instead of text so i am wondering how this could be made possible.
the above code works for changing the TV volume but not switching the input because the volume is a number but the input channel is text.
I know the numbers that are being used by the TV API but i want to tell my google home to to switch an input channel instead of a number.
Thanks in advance for the support.
https://<username>:<password>@<URL>:<PORT>/json.htm?type=command¶m=switchlight&idx=<ID>&switchcmd=Set%20Level&level={{TextField}}
